Old 02-19-2012, 12:14 PM   #1
Unhappy
Electrical power disappeared from switch to receptacle
I have lost power to the electrical recepticle in my bathroom in my apartment.
There is a switch box next to the door with two switches, one for lights and one for overhead exhaust fan. On the same wall, 2 1/2 feet away from the switch bax is a duplex receptacle. That receptacle lost electrical power.
I am not a licensed electrician but I have had much experience with wiring, having worked as a theatrical stage electrician, installed all the wiring in a new 5 bedroom home I built, and performed numerous home electrical installations and repairs.
I opened the switch box and found four wires coming into the switch box - 1. the main power wire; 2. the wire running from switch to lights; 3. the wire running from switch to fan; and 4. a wire running, I assume, to the receptacle. The wires appear to be in good condition, none frayed, and all securely twisted together and capped where the separate bundle of hot wires are connected together and where the second second bundle of the return white wires are bound together. I located the main line, which is properly connected to the two switches with both the lights switch and fan switch properly connected and operative. The main line is also bundled with the fourth wire. All the black wires are hot, however no power is getting to the receptacle.
There has been no construction or disturbance to the wall area between the switch box and the receptacle - no sign of nails on either side of the plaster board walls.
How do I approach this problem?
craighank is offline   Reply With Quote
Old 02-19-2012, 12:49 PM   #2
Code05's Avatar
did you check voltage at the terminals of the receptacle?
continuity between the wires in the boxes to be sure you have the correct power feed to the receptacle?
Code05 is offline   Reply With Quote
Old 02-19-2012, 01:23 PM   #3
From your explanation, I douibt that the receptacle is fed from that switch box. It is probably on another circuit. I assumed you've already used a multimeter to test for voltage at the receptacle, so start by checking your panel to see if any breakers have tripped, then check and reset the gfis in your house, which could be feeding your bathroom plug.
hawkeye11 is offline   Reply With Quote
Old 02-19-2012, 02:06 PM   #4
Electrical Contractor
Did you look for a tripped gfci?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
Welder Receptacle - What Electrical Box SNAFU Electrical 4 10-26-2010 10:45 PM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 07:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 06:45 PM
