Old 01-15-2013, 08:54 PM   #1
Electrical in porch?
I have a screened in porch; well actually a glassed in porch. It is on the original plans for the house. It has exterior siding on the inside walls and the floor is decking. I don't know why they just didn't put in a sunroom, but they didn't.
Anyhow, the outlets are exterior with waterproof caps. Is that necessary? There is no more chance of them getting wet than any interior outlets; but I know code can be funny.
Toller is offline   Reply With Quote
Old 01-15-2013, 09:01 PM   #2
If it now totaly enclosed then there not needed.
Got a picture.
Old 01-15-2013, 10:10 PM   #3
Licensed electrician
Doesn't sound like the weather can get in. Regular trim pates should be fine.
Old 01-16-2013, 12:16 AM   #4
" Euro " electrician
frenchelectrican's Avatar
If you are aware with the screened in porch., The receptales it have to be RCD'ed ( GFCI'ed ) so keep that in your mind on this one.
Merci,
Marc
Plans for Retrofitting Concrete Porch - Advice? BSponz1 Concrete, Stone & Masonry 1 05-07-2012 09:35 PM
Front Porch Extension km5tq Building & Construction 7 02-16-2012 04:33 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
Installing New Porch Light, Electrical Box GeauxCajuns82 Electrical 1 12-19-2008 06:16 PM
