Old 01-13-2012, 03:10 AM   #1
Electrical passing through exterior wall of house into attached garage
Need to run a new 20A circuit via 12/2g romex from my attic to my garage. I'll be using normal indoor NM-B. Garage is attached, however was built as an addition to the home. There's no direct doorway between the garage and house, if that matters.
The attic and garage walls overlap quite a bit.
If I want to run a cable through here, what do I need to do to be electrical code and fire code compliant?
I figure I'll have a junction box as soon as the cable gets in the garage, so it can split off the different directions that it needs to go. (It will come in the middle.)
I have fire rated caulk (4hrs) that I can seal with both sides - is that good enough? Or, do I need to do something else like have a special junction box?
darlingm is offline   Reply With Quote
Old 01-13-2012, 03:44 AM   #2
Julius793's Avatar
I don't see anything wrong electrical wise, about filling the whole you drill, it will probably vary be area.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Attached garage, fire codes violation? Grymph Building & Construction 38 07-04-2011 06:57 PM
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 10:23 AM
Need some help with garage electrical issue Holt Electrical 25 06-21-2010 01:59 PM
Garage electrical. Moose71 Electrical 5 01-01-2010 09:31 PM
Subpanel Questions/Running electrical to garage. FlyGuy Electrical 28 05-24-2008 11:50 PM
