Electrical Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 11:12 AM   #1
electrical panels
Main panel hom1224M100TC Homeline
Sub Panel hom612L100
I want to use tandem breaker and homt and homt 15-15 are supposed to work. a licensed electrician and machinist tried to get them to work..Neither would seat in either panel.
can someone:
1. tell me how to remedy
2. how to contact homeline
thanks. larry
lrrymclghln is offline   Reply With Quote
Old 05-01-2010, 11:46 AM   #2
Master Electrician
Rewards Points: 3,808
http://www.schneider-electric.us/
brric is offline   Reply With Quote
Old 05-01-2010, 12:33 PM   #3
Licensed electrician
Rewards Points: 1,464
Perhaps if you describe the problem and how you are trying to install the breakers someone might have an idea of what is going on.
Old 05-01-2010, 01:26 PM   #4
the breakers will not seat. the slot on the breaker does not match the part on the the panel
Old 05-01-2010, 01:47 PM   #5
Master Electrician
Are you sure the panel is a Homeline and not a QO? Square D catalog indicates those panels should accept 12 and 6 tandems respectively.
Old 05-01-2010, 02:19 PM   #6
thanks.
the label says homeline and everone supplier i speak with says they should work but they dont.
the breakers should just snap in but the only way they would fit is if you used a sludge hammer to seat them.
appreciate the help. larry
Old 05-01-2010, 03:41 PM   #7
Just call me Andrew
Rewards Points: 1,020
Can you post pictures?
Andrew
secutanudu is offline   Reply With Quote
Old 05-01-2010, 04:48 PM   #8
Electrical Contractor
kbsparky's Avatar
It sounds like a non-homeline breaker trying to be jammed into a homeline bus. But I have seen crazier things ...
-KB
Old 05-01-2010, 05:37 PM   #9
the model # of the panels is what i listed and the model # of the breakers is what is listed on the breakers.
i've been trying to get some type of access to homeline but no luck.
looks lie i am stuck. i can chaqnge the sub panel esily enough so that might be the simplest direction.
thanks for your help
Old 05-01-2010, 05:41 PM   #10
kbsparky's Avatar
Installing tandems into a Homeline panel can be a tricky thing. You have to slide the backside of the breaker firmly into the pan rail slot before the breaker will properly seat into the buss. It's almost a matter of pushing it backwards to seat into the pan rail, then swiveling the breaker down on the buss.
Try again.
-KB
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
electrical panels tyorkie Electrical 5 06-01-2009 04:06 PM
