Old 06-01-2009, 12:58 PM   #1
electrical panels
I am needing to add a water heater (electrical) to an older home (1960's) The house was built and added onto at least twice and we have been remodeling. I finished a bath room last year and placed an electric water heater at that time. Because of the way the house was built it also had a gas water heater. I want to replace that one also and don't know if the panel is big enough. There is a 50 AMP breaker running to an old screw in fuse panel which services the old part of the house including the AC and heating as well as all the lights and switches. The kitchen, addition and new bath and water heater are in the new panel. I think it is a 100 to 125 amp panel. IS there enough power to add the second water heater or do I need a bigger panel?
tyorkie is offline   Reply With Quote
Old 06-01-2009, 01:18 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
electrical panels
I'm not an electrician, but just to put in 2 cents until one comes along, you need a 30 amp dedicated circuit for a standard water heater. You need to check your existing panel to see what it is first. Whether your existing panel will handle another 30 amp circuit needs to be calculated by an electrician, and I also would take the opportunity to have them replace that old fuse breaker panel too.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-01-2009, 03:52 PM   #3
J. V.'s Avatar
electrical panels
How many spare slots for breakers do you have. If you have two, then you can install a 2 pole breaker of the correct size in it. As said above a WH usually is a 30 amp 120/240 volt circuit. That means you will need 4 wires H-H-N-G.
What size wire is feeding the old fuse panel? If its closer to the WH, you can install a new small sub panel for the water heater there..
Don't forget you need a disconnect at each electric WH.
J. V. is online now   Reply With Quote
Old 06-01-2009, 04:20 PM   #4
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
electrical panels
That's a new one on me. I've never seen a 240/120 water heater.
wirenut1110 is offline   Reply With Quote
Old 06-01-2009, 04:56 PM   #5
electrical panels
That's kind of like suggesting that, if you have check left, you must have money in the bank.
Not enough info to determine if you are good/safe to add more load.
Are all other apliances gas (except the one HWH)? If so, you will be OK. The more leec load you have, the more you will push your 100/125 service.
Google "residential load calculator" an put your numbers in.
220/221 is offline   Reply With Quote
Old 06-01-2009, 05:06 PM   #6
electrical panels
There's a reason he's retired.
jerryh3 is offline   Reply With Quote
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
Where to get bathroom panels similiar to rebath? Side panels? twilightcall Remodeling 2 03-06-2008 10:19 AM
