Electrical Panel Upgraded... Any Additional Work Needed? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 07:11 AM   #1
Thadius856's Avatar
Rewards Points: 504
Electrical Panel Upgraded... any additional work needed?
Recently purchased this home. Inspector said that the panel appeared to have been recently upgraded. I just want to be sure that everything is safe and good to go.
I have a Square D box with plain (non-AFCI) breakers. It appears to be 200A service via two 100A breakers attached to a service disconnect. The left side of the panel has a "Smart Meter".
The cable box, gas main and telephone interconnect are all bonded. Neutral and grounds both attach to the same bar, which is in turn connected a grounding rod via (8 awg?) bare wire and zinc bonding clamp.
Can post a picture in the morning if needed.
Does anything stick out as being in need of upgrade?
Thadius856 is offline   Reply With Quote
Old 08-06-2011, 07:14 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Couldn't your "inspector" have checked all this? Isn't that what he is paid for???
Old 08-06-2011, 07:20 AM   #3
Licensed electrician
Rewards Points: 1,630
Two 100 amp breakers do not equal 200 amps.
You should not be able to see the ground clamp if the rod were driven below the surface like it should be. The conductor going to the rod should also be larger than #8.
Old 08-06-2011, 08:48 AM   #4
I=E/R
a7ecorsair's Avatar
That is a 100 amp service
a7ecorsair is offline   Reply With Quote
Old 08-06-2011, 11:14 AM   #5
Thadius856's Avatar
Rewards Points: 504
The home inspector gave a brief looking over to the panel, and said everything looked fine. I just want to be sure, considering he tested every outlet in the house before telling me they weren't grounded. He did point out several structural and plumping issues, which I've fixed. Anyway, I figured a second opinion couldn't hurt.
Guess it's 100 amp service. For a smaller home, is there anything wrong with that, so long as I'm not tripping the main or any individual circuits?
The grounding rod most certainly is not driven below the surface. It's about 6" above ground, as a matter of fact. The wire may very well be larger than 8 awg, but I don't have any crimpers that strip larger than 10 awg so I can't really tell.
Here's some pictures, in case they help at all.
Edit: Full resolution links
http://img825.imageshack.us/img825/3372/photo1yl.jpg
http://img220.imageshack.us/img220/7343/photo2pdo.jpg
Electrical Panel Upgraded... any additional work needed?-photo-1.jpg   Electrical Panel Upgraded... any additional work needed?-photo-2.jpg
Old 08-06-2011, 04:27 PM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The connector for the ground rod is a concern. First, I don't believe it is listed for direct burial or for use on a ground rod. Second the GEC conductor is not terminated correctly on the connector. Third, the ground rod needs to be driven flush with the finished grade. I'm curious to know how the GEC is connected at the panel. It looks like the GEC is not going to be long enough to reach the ground rod after it is fully driven. Which means it may have to be replaced. Use a #6 bare copper to the rod with the correct listed connectors. Check the GEC to the waterpipe. If it is not #6 copper or aluminum, replace it as well and use the proper and listed connectors. The GEC to the waterpipe can be #8 copper but it will have to be in conduit. Use a kennyclamp where the GEC's enter the panel.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Electrical Panel Knockout Help atw58 Electrical 15 05-04-2016 05:54 PM
Maxed out main panel and sub panel - additional 240v needed netcustoms Electrical 4 03-12-2011 11:40 AM
Ran a wire to an electrical panel for my first time Red Squirrel Electrical 17 07-19-2009 10:09 PM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 09:38 AM
