Electrical Panel In Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 06:09 PM   #1
Question
Electrical Panel in Shed
How high does an electrical panel need to be off the floor. I know the max height to the shut off breaker is 6ft 7 inches. But how low can the panel be?
magate is offline   Reply With Quote
Old 06-30-2010, 06:10 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there is no minimum required height. If the floor is where it might get wet, the inspector would probably require it be raised to prevent water intrusion.
Old 06-30-2010, 06:13 PM   #3
Thanks,
I did read that somewhere but I needed to be sure. I am in Canada. Would that be the same here? Once again, thank you so much for the quick post.
Old 06-30-2010, 06:17 PM   #4
nap
You talking to me?
nap's Avatar
Canada?
That one I can't answer. There are a couple of your brethren that post here regularly so keep an eye on the thread. Hopefully they will respond with an answer that is applicable to Canada.
Old 06-30-2010, 06:18 PM   #5
In Canada they can also be installed sideways if needed
But my shed panel is fairly small & does not take up much room
Old 06-30-2010, 06:19 PM   #6
Originally Posted by nap View Post
Canada?
I certainly will. Once again, Thanks so much.
Old 06-30-2010, 06:24 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I think someone here had posted a pic where their panel was like a foot off the ground.
I think it's more a thing of common sense. I would put it at eye level for ease of access and minimize the risk of water. Ex: you drop a bucket of water on the ground, if the panel is right on the ground it could splash right on the panel.
Old 06-30-2010, 06:32 PM   #8
I certainly understand where your comming from. I have 70 feet from my house to shed. A friend of mine gave me 80+ Ft of Tech90 Armored cable. I have the cable ran from the house to the shed. I was hoping to get this in at eye level but the cable wasn't long enough :0(. Could I put a junction box in at the 2 foot level and run wire then to the panel? Could I store the under my bench in a cabinet? What are the options other than purchasing a brand new run to the shed.
Thanks Again!!
Old 06-30-2010, 06:34 PM   #9
No, that pic was of a stud wall on top of a cement wall
It did look like it was inches off the floor
Junction box & some extra wire ?
How high off the floor will it be ?
Old 06-30-2010, 06:37 PM   #10
If I could run the wire into the shed, let it Stop at 3 ft, "Where it currently stops" Then put in a juntion box or something to join extra wire and bring it up to the panel, perhaps I can then get the panel to eye level?
Old 06-30-2010, 08:04 PM   #11
nap
You talking to me?
nap's Avatar
IN THE US you could do as you suggest. Again, I don't know Canadian code but it does appear to be very similar to ours in many cases.
Old 07-01-2010, 06:08 PM   #12
Rewards Points: 502
I'd get an outdoor rated pannel. a shed's roof often is not a priority.
forresth is offline   Reply With Quote
Tags
electrical , how high , shed
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
New Electrical Panel Box criehl Electrical 17 05-14-2009 08:05 AM
Water Near Electrical Panel jamiedolan Electrical 7 09-21-2008 10:03 PM
Help with electrical sub panel chrismc77 Electrical 6 08-12-2007 02:36 PM
