Old 05-01-2011, 04:20 PM   #1
electrical panel screws
I'm adding a circuit to my sub-panel, however I'm short the screws that hold the neutral wires down. Are these a special type or does any standard machine screw with the proper thread and head size work?
Thanks for any help.
readar is offline   Reply With Quote
Old 05-01-2011, 04:28 PM   #2
A "Handy Husband"
rjniles's Avatar
Go to an electrical supply or big box and buy a ground bar kit;
Cannibalize the screws
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Coastal South Carolina
Old 05-02-2011, 02:41 AM   #3
The screws should be the same material as the busbar, or you could create issues with galvanic corrosion if there were moisture. I believe most of those are tin plated brass, while a common steel screw is typically zinc coated. The more significant issue is that dissimilar metals have different expansion rates when heated. Dissimilar expansion rates can cause fasteners to loosen, which you don't want in an electrical panel.
If you add the two effects together, it gets worse, as corrosion creates more resistance, which makes heat. Heat plus a fastener with a different expansion rate can cause it to loosen.
Robo_geek is offline   Reply With Quote
Old 05-02-2011, 10:26 AM   #4
That's good info, thanks. I'll try to hunt down the proper screws for this.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Electrical Panel Installation mary h Electrical 12 06-06-2010 09:54 PM
Ran a wire to an electrical panel for my first time Red Squirrel Electrical 17 07-19-2009 11:09 PM
New Electrical Panel Box criehl Electrical 17 05-14-2009 09:05 AM
