Electrical Panel Positioning - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 12:04 PM   #1
I am in the process of designing a new home. The home will have a crawl space rather than a full basement and therefore the electrical panel must be positioned on the main floor of the home. The ideal location would be in a utility room where I have also located a clothes washer and dryer as well as a wash tub. How far does the electrical panel need to be from the wash tub and washing machine?
Lseguin is offline   Reply With Quote
Old 01-19-2011, 12:14 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Shouldn't the meter panel be outside? Or maybe this is a sub-panel?
Andy.
AndyGump is offline   Reply With Quote
Old 01-19-2011, 12:29 PM   #3
The main panel can be inside but it has to be a certain distance from any plumbing fixture.
Old 01-19-2011, 04:49 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
Outside panels are a regional thing. An inside panel must be located in a specific sized space clear of any obstructions. It also should be located close to the meter as there are rules regarding lengths of unfused conductors. There are ways around this, but they vary from location to location.
Working space requirements are 30 inches side to side. The panel can be located anywhere within those 30 inches. There must be 6.5' in height clear. This is minimum headroom per code. The panel space must also be clear 3' in front. of the panel.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
AndyGump (01-19-2011)
Old 01-19-2011, 04:50 PM   #5
Master Electrician
Rewards Points: 3,862
Please cite a reference for this statement.
brric is offline   Reply With Quote
Old 01-19-2011, 07:55 PM   #6
Rewards Points: 6,652
My meter is outside, and the main panel is down in my basement. Again, it is a regional thing. Nothing to cite. As for the plumbing fixture citation, you can not have the panel over a sink, above a water heater or in a clothes closet, or in a Bathroom. As long as you can have a 3' bubble in front and to the sides, that if you have to jump, you are able to do so without tripping, or grabbing onto a metal object (ie sink, faucet, water heater), or in a sink full of water.
Old 01-19-2011, 08:12 PM   #7
Rewards Points: 3,130
I hardly think it's a "regional" thing. The NEC is very clear about how long an unfused conductor can be. I've lived in over 20 states and have never seen a breaker panel outside or a meter box inside. If your breaker panel is a long way from your meter (like my current one is), you simply use a CSID (combination service entrance device) which is nothing more than a meter box with the main breaker in it.
Old 01-19-2011, 08:17 PM   #8
Master Electrician
Nothing to cite because the statement is false.
The Following User Says Thank You to brric For This Useful Post:
Speedy Petey (01-19-2011)
Old 01-19-2011, 08:25 PM   #9
Rewards Points: 756
The NEC is not clear about the distance. It just says "nearest the point of entrance". Also, just cause you've never seen it, it doesn't exist? Go to California to see outdoor 3R service panels. I have photos of meters that are inside the home.
Mark
busman is offline   Reply With Quote
Old 01-19-2011, 08:43 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I agree with brric.
This is just another myth perpetuated by those who don't know any better and simply follow the "I've always done it this way" mentality.
Old 01-19-2011, 08:46 PM   #11
No it's not.
Seriously? You need to get out more.
I'm not saying meters inside are at all common any more, but outside panels certainly are in certain areas.
Old 01-19-2011, 11:50 PM   #12
Scared Electrician
Saturday Cowboy's Avatar
hallways IMHO are excellent places to put panels. nobody even piles stuff in front of them.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-20-2011, 07:09 AM   #13
Brings to mind the Hoarders series, and the episode on Holmes on Homes, where the couple had everything they could stuff in the house, but were wondering why the HVAC system would not work properly.
Electrical Panel Knockout Help atw58 Electrical 15 05-04-2016 05:54 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Recessed Light & Electrical Panel MartinD Electrical 3 09-30-2010 07:42 PM
Upgrading an electrical panel syndicate1 Electrical 6 07-05-2010 10:35 PM
