Electrical Panel Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 01:53 PM   #1
electrical panel grounding
Can I put two ground wires in the same terminal of the panel ground strip
Terrence Blanch is offline   Reply With Quote
Old 12-04-2010, 02:30 PM   #2
Mad Scientist
Usually, yes. But you have to check the panel label to be sure. It should list how many of each size wire you can put in each ground terminal.
Note that you can't do this with neutrals, those need to be one wire per hole.
McSteve is offline   Reply With Quote
Old 12-04-2010, 04:37 PM   #3
Electrical Supplier
Rewards Points: 150
I thought it was one wire per screw on anything unless otherwise identified as such.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 12-04-2010, 04:42 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
that is what McSteve said.
Sub panel wiring & grounding kwcamaro Electrical 1 03-06-2010 08:58 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
new Main Panel Grounding lrr81765 Electrical 8 10-09-2008 12:16 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
