Electrical Panel Ground Wires - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 01:11 PM   #16
Rewards Points: 242
Originally Posted by stubie View Post
Then we need to affirm your main bonding jumper. This is generally a screw or other conductive means to join (bond) the neutral bar(s) to the metal of the panel. This is critical if the grounds rely on the metal of the panel to move fault currents to the neutral bus and ultimitely the service neutral so that your fuses can open.
Here's a better picture of the neutral bars. I assume (hope) you're referring to the large screw in the middle with the large white wire. If not I think I'm in trouble lol.
As for the grounds, I looked a little closer and found another grounding bar in the top left hand corner of the panel, which is where the rest of the wires are grounded to. There are some with up to 3 wires in one hole. Is this ok?
Lemkie is offline   Reply With Quote
Old 10-04-2012, 01:50 PM   #17
Rewards Points: 150
Now I don't see the pic.
Dave632 is offline   Reply With Quote
Old 10-04-2012, 01:59 PM   #18
Rewards Points: 242
Haha yes the link would help...
my bad!
Old 10-04-2012, 02:24 PM   #19
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
They show for me ... maybe you can see them now ?
Nope. I'll check at home. Probabley some sort of filter on the proxy.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-04-2012, 05:19 PM   #20
Rewards Points: 242
Rather than starting another post I figured I'd ask this here as well. Is it legal/safe to connect 5 14 gauge wires together in an octagon box. The box appears to be 2 inches deep. It has 5 wires going in (5 black, 5 white, 5 bare) all 5 are wire nutted together. The base has a pigtail also that goes to the green ground screw. From what I can see there is one wire bringing power. From there 1 other wire connect to a ceiling fan/light, while the other three go to three separate outlets. Two of these don't go anywhere else while the third appears to go to two more outlets...
This seems like a lot of wires for one junction so I just want to make sure...
Old 10-04-2012, 07:16 PM   #21
Rewards Points: 242
I did a little research and think that the box is one cubic ft. short. From my calculations the ten wires count to 20, plus 1 for the ground, plus 1 as the box has two built in clips. 22 cubic feet in a 21 cubic foot max box. I think I'll be getting an add on. Can someone confirm this?
Old 10-05-2012, 09:28 PM   #22
Rewards Points: 160
Presumably you mean cu. inches. Straighten out your units and post question as a new thread.
philS is offline   Reply With Quote
Old 10-05-2012, 09:35 PM   #23
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
What? We all know he means inches!
sublime2 is offline   Reply With Quote
Old 10-05-2012, 10:09 PM   #24
Rewards Points: 160
We do but he doesn't. You want to believe his arithmetic when he can't get the units right?
Old 10-05-2012, 11:23 PM   #25
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
How does this help him with his question?
Stop being so condescending.
Old 10-06-2012, 01:28 AM   #26
Rewards Points: 258
i can't tell you what is best and what is not. all i can do is state what i am seeing in the pictures, the four bars look to be all connected(bonded?) to the main Nutral, the two that are off set seam to be lower so that you can pass the wires under the other set. It also seams very clean an unoxidized for such an out dated load center/fuse box since it uses fuses not circut breakers
redman88 is offline   Reply With Quote
Old 10-07-2012, 11:29 AM   #27
Rewards Points: 242
Well that's a bonus. Thanks. As fat as the cubic feet as opposed to cubic inches... Ya my bad...
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Bare Ground Wires MrBill_DIY Electrical 4 10-05-2008 07:05 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
