Electrical Panel Expansion - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 08:28 PM   #1
Fire Hazard
My electrical panel has 2 open slots. However, they are side-by-side in the bottom (horizontal) row. I have been told that you should have 2 open slots next to each other in same column for expansion to a sub-panel, if needed.
Is it against code to leave my box the way it is (2 open slots next to each other in the same row), or do I need to get the unused slots in adjoining positions in the same column?
Thanks again,
- Mike
Portland, OR
Superchunk is offline   Reply With Quote
Old 11-08-2012, 08:36 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
If you need a subpanel, then you need the open spots to be next to each other.
You can move one breaker above the open spot to the other side of the panel to make room.
If you are not adding anything, you can leave it as is.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
Bonding Electrical Panel folkda Electrical 3 11-03-2012 12:37 AM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Electrical Panel - Ground Bar/Wiring and Safety cfreak Electrical 31 09-11-2011 09:10 AM
Upgrading an electrical panel syndicate1 Electrical 6 07-05-2010 11:35 PM
