Electrical Panel Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 04:32 PM   #1
Electrical panel code question
I'm new here, but it looks like there are experts to answer my question.
I had the old fuse panel in my rental unit (triplex) upgraded and the electrician needed to install a new meter box, which included relocating it. (Note, there were multiple places to relocate it to.)
The work was done a few months ago without me being able to see it since I'm not in the area. It was signed off by the city and I thought things were good. Now, I had a tenant want to move out and found that where they placed the new meter box significantly blocks the entrance to the unit.
The doorway wasn't terribly wide before, but with the meter box there is only about 14-15 in. to pass through. My tenant found she is trapped as she can't move any furniture or larger items through the 14-15 in. gap.
First, I called the electrician and they said to get lost because the city signed off on it. I then called the city and they claim it's fully to code and there is nothing they will do. He said it needs 36" in front and 36" to the left of the box and the fact that it's right there in a doorway doesn't matter.
I'd like to get input from some online experts if possible. It doesn't seem reasonable that they could sign off on blocking the only entrance to a building in such a manner.
I've included some pics of the issue. Sorry for the quality, but I had someone living there with a cell phone send them to me.
rap4rent is offline   Reply With Quote
Old 12-17-2012, 04:40 PM   #2
TTW
TTW's Avatar
What is your location?
In Maine the power Co. specifies the location.
However, in this case what the heck happened to common sense?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-17-2012, 04:45 PM   #3
Sorry, I should have specified that this is in South Dakota. The city guy claimed he and the electrician talked about it and that was the only place they could think to put it. It didn't sound like the city mandated where it was placed.
I also just talked to another electrician to get his input. He went over and checked it out and said there were at least two other good options where it could have been relocated, although they would have probably been more expensive.
Old 12-17-2012, 04:46 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Call the building department or fire department.
Old 12-17-2012, 04:49 PM   #5
TTW
TTW's Avatar
There you go, if it blocks a proper fire egress, the inspector should have known that.
Could open up a bag of worms though...
Old 12-17-2012, 04:52 PM   #6
TTW
TTW's Avatar
Could be pretty bad if someone is moving a refrigerator and it breaks one of those meters and someone gets killed or maimed....
Just sayn'
That's when the lawyers get involved.
Old 12-17-2012, 05:44 PM   #7
Thanks for the recommendation. I hadn't considered calling them in on it.
Any idea if an electrician is responsible for getting sign-off from the building department in a case like this, or do they only ever deal with the electrical inspector?
Old 12-17-2012, 05:56 PM   #8
TTW
TTW's Avatar
Varies widely depending on the area. You might check with whoever issues permits in your area.
Old 12-17-2012, 08:32 PM   #9
Engineer
Rewards Points: 161
No kidding...
diystephen is offline   Reply With Quote
Old 12-17-2012, 11:48 PM   #10
TTW
TTW's Avatar
It's sort of like putting a toilet in a hallway...
Old 12-18-2012, 07:49 AM   #11
joed's Avatar
Rewards Points: 12,446
Rotate your picture and put them right side up. It looks strange to see meters on the ceiling and floor.
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Upgrade panel, also part realestate question szcott Electrical 6 04-29-2011 06:11 AM
Placement of Electrical Panel theatretch85 Electrical 4 01-05-2010 12:05 AM
Electrical Code question Bean44125 Electrical 4 12-16-2009 12:31 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
