Old 01-20-2010, 06:20 PM   #16
Electrical Panel Bus Bars
Originally Posted by spark plug View Post
... as was stated that there is a Disconnect Switch ahead of the "Panel" it (the Panel) is not considered a MAIN panel and it MAY NOT be Bonded/Grounded
The OP didn't say there was a disconnect switch ahead of the panel. We don't know yet...
Willis
williswires is offline   Reply With Quote
Old 01-20-2010, 07:42 PM   #17
Electrical Contractor
kbsparky's Avatar
Panels sold in Canada apparently have equipment grounding bars pre-installed in them. I took a look at some boxes when I was there over the holidays.
It's no surprise to me that Federal Pioneer boxes have them as well.
-KB
Old 01-20-2010, 09:41 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
I wasn't aware of that but do you think they would have 6 short ones installed in the panel?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-20-2010, 09:59 PM   #19
Wire Chewer
Red Squirrel's Avatar
That's kinda an odd configuration, I'd be curious to see a pic of that. I have a Federal Pioneer Stab-Lok as well but it only has two bars (one for ground and one for neutral). Mine is setup as a "sub panel" though, since I have a main disconnect switch beside it.
Old 01-21-2010, 08:41 PM   #20
Question
Originally Posted by Speedy Petey View Post
Then WHY is Federal PIONEER still used and installed in new construction to this day in Canada???
I thought F Pioneer was not the same thing as our old FPE. That is what my Canadian friends tell me.
Let me put my Two cents in. When I resided (a fancy way of saying, "I Used To Live") in (Montreal, Que.) Canada, Pioneer/Federal was considered a high quality breaker, and it was! But I read a recent piece of info. from Inspectapedia.com; that some lines of the Pioneer Breakers, Not the Panel, as is the case with FPE Breakers and Panels in the USA, were having problems, and are being replaced. The point is that there always was a distinction between Pioneer, Canada and regular FPE products. (Ultimate symbol of Confusion)!
spark plug is offline   Reply With Quote
Old 01-21-2010, 08:50 PM   #21
Question
Originally Posted by codeone View Post
You need to go back and read Article 200 of the NEC.
The neutral as most people call it is actually a grounded circuit conductor!
It carries current most of the time. And is bonded or grounded intentionally at the service therefore called a grounded conductor.
That --as you say-- was a poor choice of words. What I meant to say was that a SUBPANEL (after a Main Disconnect Switch) may not be BONDED, since it is no longer considered Service Equipment, even though it is the Primary Branch Circuit enclosure.?!
Old 01-21-2010, 09:50 PM   #22
No did not miss the main point. Most people and electricians do not understand what the GROUNDED CONDUCTOR is, They call it a neutral in the industry, however it is almost never neutral, only in multiwire circuits can it be neutral. It is a CURRENT carrying conductor that is bonded to the Ground in the main service. The NEC recognizes it and calls it a Grounded Circuit Conductor. Neutral implies that it does not carry current. If it did not carry current and shorted to the equipment grounding conductor it would not trip a breaker or blow a fuse.
As taken from NEC 2008
2008 NEC—Article 100
Neutral Conductor. The conductor connected to the neutral point of a system that is intended to carry current under normal conditions.
Neutral Point. The common point on a wye-connection in a polyphase system or midpoint on a single-phase, 3-wire system, or midpoint of a single-phase portion of a 3-phase delta system, or a midpoint of a 3-wire, direct current system.
FPN: At the neutral point of the system, the vectorial sum of the nominal voltages from all other phases within the system that utilize the neutral, with respect to the neutral point, is zero potential.
So yes, a neutral is now defined by the NEC!
ElectGangBox is offline   Reply With Quote
Old 01-21-2010, 11:18 PM   #23
Here's the photo. I'm a little confused because I've seen this configuration in all my research and the sticker inside the panel front describes the usually configuration of white wires on one side, green(bare) on the other. I had a licensed electrican do some work on it and he didn't say a thing.
dave_80 is offline   Reply With Quote
Tags
bus bar, electrical, grounding, panel, stablok
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
New Electrical Panel Box criehl Electrical 17 05-14-2009 09:05 AM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 10:38 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
