Electrical Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 06:47 PM   #1
electrical panel
Hi i had a problem two years ago with the lights in my bedroom and kitchen going off without tripping the breaker i changed some plugs and still did it so we found out that the back off the panel was melted so we swicthed the box and was fine now two years later started doing the same thing do you know why
granskofski is offline   Reply With Quote
Old 08-05-2010, 06:49 PM   #2
Electrician
Proby's Avatar
That's one long sentence you got there
How do you get the lights to go back on after they shut off?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 08:13 AM   #3
They came back on in a couple of seconds by thereself.
Old 08-06-2010, 08:28 AM   #4
Electrician
Proby's Avatar
So I'm going to make the assumption that the problem in your panel wasn't the issue with the lights, and that you have a loose connection somewhere else.
When looking at the lights that are shutting off, I would find the closest one to the panel. I would then open up the switch box and look for a loose connection, if nothing is found then I would take the light down and look in it's box.
Old 08-06-2010, 10:27 AM   #5
I replaced all the sockets that were involed. After i replaced the panel it all stopped for two years and now tuesday it did it twice.
Old 08-06-2010, 10:32 AM   #6
" Euro " electrician
frenchelectrican's Avatar
If they were backstabbed you have to move them to the screws and get them tighten them down good.
What conductor size and breaker size are you using on this circuit ??
For 15 amp circuit you can use 2.5mm≤{#14 AWG } while the 20 amp circuit it must have 4.0mm≤{#12 AWG }
Merci,
Marc
Old 08-06-2010, 10:51 AM   #7
gmhammes's Avatar
is there a junction box anywhere you didn't check and or replace? The connection could be loose in there.
gmhammes is offline   Reply With Quote
Old 08-06-2010, 12:58 PM   #8
No i didnt replace or check the junction box. But why all of a sudden would it start again?
Old 08-06-2010, 01:11 PM   #9
Electrician
Proby's Avatar
There could be a loose connection anywhere. I would also check the switchboxes.
Electrical Panel Knockout Help atw58 Electrical 15 05-04-2016 05:54 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Upgrading an electrical panel syndicate1 Electrical 6 07-05-2010 10:35 PM
electrical fuse panel Snell Lancaster Electrical 4 01-10-2010 11:20 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
