Old 05-30-2012, 10:15 AM   #1
electrical panel
i have to replace my panel in my house i just bought it is a pacific coast panel. i have a 4 bed 2 bath and laundry room what size panel do i need?
eric216 is offline   Reply With Quote
Old 05-30-2012, 10:24 AM   #2
It was a dark and stormy
Yoyizit's Avatar
electrical panel
Possibly you bit off more than you can chew.
Old 05-30-2012, 10:30 AM   #3
Licensed electrician
electrical panel
What size panel is there now? Do you plan on any expansion or adding large loads like a hot tub?
eric216 (05-30-2012)
Old 05-30-2012, 10:33 AM   #4
kevinp22's Avatar
electrical panel
Replacing a main panel is not a DIY project in my opinion (not even allowed in my area).
However, if you are trying to get a general idea you need to run a demand load calculation.
http://www.electricalknowledge.com/SFDLoadCalc.asp is a link to one. there are many others. search past threads as well.
Keep in mind you cant just replace say a 100amp panel with a larger 200a panel -- the service size probably has to change. this is an even more major project that is beyond the reach of "almost" every DIY
Not blowing you off - people here can help you estimate your service size requirements if you provide more detail.
kevinp22 is offline   Reply With Quote
Old 05-30-2012, 11:46 AM   #5
J. V.'s Avatar
electrical panel
Troll, it's Federal Pacific dummy.
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Home Electrical Panel Main thornton0715 Electrical 5 11-08-2011 09:59 AM
Electrical Panel - Ground Bar/Wiring and Safety cfreak Electrical 31 09-11-2011 09:10 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Electrical Panel Knockout Help atw58 Electrical 14 07-24-2009 11:51 AM
