Electrical Oven Install - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 04:27 PM   #1
Electrical oven install
I recently purchased a new electrical oven that comes with a 3 pronged power cord. The original oven was hard wired. The power cord is hooked up to the oven, so that end of it is ready. My question is - what exactly do I need to hook up the oven to electricity?
ctoph75 is offline   Reply With Quote
Old 07-10-2011, 06:01 PM   #2
Rewards Points: 6,652
You need the proper outlet for the oven, since it is already corded.
Old 07-10-2011, 06:31 PM   #3
Rewards Points: 512
Will this (a 3-wire cord) be code compliant considering a new receptacle needs to be installed?
Old 07-10-2011, 06:55 PM   #4
Only if it is an existing run. New pull I would say that it would fall under the new NEC rules. My dryer is still 3-wire, and was that way when we moved in eight years ago. One of the last things on my list to change over, after I get the kitchen finished some time next year.
Old 07-10-2011, 07:24 PM   #5
Rewards Points: 512
Well, considering it was previously hard-wired I would think that the addition of a receptacle might make it a new install, but I suppose the opposite could be true since the wiring is existing and not being changed.
Which article covers these installs?
Old 07-10-2011, 07:35 PM   #6
If they hard wire the stove, either way it is the same if you have to replace an outlet. Code violalatio, would be if the local states that since the stove is new to the facility, they would have to bring up to newest code, but that is far fetched.
Old 07-10-2011, 08:26 PM   #7
Electrical Contractor
kbsparky's Avatar
What is the NEMA configuration of the cord? Care to upload a pic?
-KB
Old 07-10-2011, 09:09 PM   #8
I=E/R
a7ecorsair's Avatar
You wouldn't be hinting that the oven could be straight 240....
a7ecorsair is offline   Reply With Quote
Old 07-10-2011, 11:06 PM   #9
kbsparky's Avatar
I most certainly would ....
-KB
Old 07-11-2011, 09:28 AM   #10
http://products.geappliances.com/App...&Sku=JBS55DMBB
That's the oven. My guess is I use the existing hardwire to an appropriate receptable box? As you can probably tell, I'm not an electrician.
Old 07-11-2011, 10:12 AM   #11
I=E/R
a7ecorsair's Avatar
That is not an oven.... it is a range, there is a difference.
That range is not supplied with a cord so someone, probably where you purchased it, added the cord.
This project may be outside your skills....
Old 07-11-2011, 10:17 AM   #12
My mistake. I tend to say oven rather than range. The cord was a required purchase with the range and was connected by the deliverers. They couldn't do a complete install due to the hardwiring invovled.
In any event, I'm aware it's outside of my skills. I just need to know what hardware I need. I have a friend coming over to help with it. He'll be doing the heavy lifting, so to speak. Just looking for any insight beforehand.
Old 07-11-2011, 11:43 AM   #13
I=E/R
a7ecorsair's Avatar
You will need to determine what wires are currently in the box. Are there three wires or four? How was the old range wired?
Do you know if the box is properly grounded?
You will need two hots and a neutral for the range to work. It is possible that the old range didn't require a neutral so you may not have a neutral.
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 09:22 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-02-2011 11:09 PM
Oven - 230v - disconnect? CZSteve Electrical 2 06-13-2010 05:56 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
Replacing an oven install liquidvw Electrical 7 11-09-2009 02:34 PM
