Electrical Outlets And Granite Backsplash, How? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2006, 02:19 PM   #1
Electrical outlets and Granite backsplash, how?
i was told i might want to re-post this question here.
we are having a granite backsplash installed (along w/ the countertops), they made templates, and marked where existing outlets are on the old wall.
i am doing the electrical work.
my question. how do i raise the outlets so they are flush w/ the new backsplash? the granite is the 3cm variety, so they need to be moved out 3cm to be flush. after they finished the template, i asked the installers, and he simply said "longer switchplates screws", w/o really thinking i agreed. but that would leave the actual recepticals 3cm behind the switchplates.
any walkthroughs? or advice?
section8 is offline   Reply With Quote
Old 06-18-2006, 02:39 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Box extenders. Arlington makes them.
http://www.aifittings.com/m_9.htm
Old 06-18-2006, 02:40 PM   #3
perfect! exactly what i need.
thank you!
Old 06-18-2006, 10:59 PM   #4
The ears of your outlets should catch on the granite just as they do on the sheetrock wall. Just get longer 6/32 screws. If the ears don't catch you'll need to use a stand-off, or a nut on the back of the screws.
Sparky Joe is offline   Reply With Quote
Old 06-19-2006, 05:46 AM   #5
Longer screws alone are NOT a safe and legal option. You must have an extension of some sort.
Old 06-19-2006, 07:58 PM   #6
Legal, perhaps not, but is it done every day of the week, yes, and is it dangerous, no.
Old 06-19-2006, 08:07 PM   #7
Not by me it's not. And YES, it can be dangerous.
Old 06-19-2006, 08:20 PM   #8
Check out NEC 314.20 and www.secura-lets.com.
BIGRED is offline   Reply With Quote
Old 06-19-2006, 08:50 PM   #9
I agree it can be dangerous around combustible materials, such as paneling or plywood, but with the granite I would just get longer screws.
As for the standoffs I like using 1/4" pex tubing, its free from the plumbers and can be cut to any length, and is also very rigid.
Old 06-19-2006, 09:52 PM   #10
Whatever you say.
Old 07-01-2006, 08:53 AM   #11
I just posted a reply to your question in the other section.
HWPipes is offline   Reply With Quote
Electrical outlets and Granite backsplash, how? section8 Remodeling 6 01-08-2007 06:55 AM
