Electrical Outlets In A Closet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 11:10 AM   #16
biggles's Avatar
if the living room socket has a single pull onto it you can take the other screws within it and tap and pull a 120V romex into the closet in the same wall.think what goes on those shelf also a low socket and nose level socket might keep the wires more tight from the components.2 outlet/4 outlets per box is your choice..anything that is surge sensitive you can plug in and just lay behind the item being protested..the load on a home theater center isn't much...compared to a dishwasher,micro,frig as in and on a socket there.........
Old 05-24-2010, 11:23 PM   #17
New electrical outlet in closet
Hi,
this is a similiar question. I currently have an outlet on the outside wall of a closet. I want to add another outlet on the inside of the closet so I can provide power to a cd changer in the closet.
-Is it safe to do this? Is it up to code?
-how do you connect the outside outlet to the inside outlet for power. I guess this would be like having 2 outlets side by side. But how would they be connected?
Thanks in advance for answering
donsturdy is offline   Reply With Quote
Old 05-25-2010, 06:57 AM   #18
Installed correctly it is safe to do & meets code
You need to verify the circuit - 15a/14g or 20a/12g & use the right wire
You can't pull power from a bathroom or kitchen to another room
Also need to know box fill (size of existingoutlet box) to see if you can fit another set of wires in there
Old 05-25-2010, 03:57 PM   #19
downrightart's Avatar
Rewards Points: 150
I'd like to say I've done this or had it done....since it's been MONTHS since doing this thread....but NOT!
My pictures don't tell the tale though! Before(yes) and after (nope---unless you are looking for it!). Hehehe.....
Yes, I'm waiting on an expert.
Electrical Outlets in a closet-closet2.jpg   Electrical Outlets in a closet-closet3.jpg
downrightart is offline   Reply With Quote
How to Fix Electrical Outlets That Don't Work limitdiy Electrical 11 08-08-2009 09:44 PM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 02:06 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 09:28 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 08:53 AM
