Old 03-27-2010, 10:45 AM   #1
downrightart's Avatar
Electrical Outlets in a closet
I'm converting a closet into a home entertainment/computer area. I'm taking the closet doors off and install shelves. But, before painting, I'm thinking I need electrical outlets in.
I do have wires...actually cable wires for a tv that must have been used at one time. On the other side of the wall is our living room and about 6 inches are so to the left of the cable outlet is an electrical outlet. 'Course this would be to the right if looking from the closet. The walls are 6 inches thick through out the house (which was built in 1997).
My husband won't touch it and I definitely don't think I should! I've replaced a thermostat before while on the phone with an A/C tech that I knew from high school, but I'm thinking this might be way beyond my experience.
My questions are: How easy would this be to do? How much would an electrician cost to do this? What is the average price for this type of job?
downrightart is offline   Reply With Quote
Old 03-27-2010, 11:06 AM   #2
Electrical Contractor
Cost issues depend where you are located.
If the receptacle is located inside the same stud bay, this is a very easy job to complete.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-27-2010, 11:25 AM   #3
I'm sure it's less expensive in GA. Everything is expensive in FloriDUH! Maybe the Boss (my husband) is right. It might cost me an arm and a leg, but I'd rather that be figuratively speaking and not literally!
It just looks like it would be pretty simple with a hole already there, but whatta I know.
Thank you for responding JB. I appreciate it.
Old 03-27-2010, 05:08 PM   #4
Ummm...........will one outlet be enough guys? I'm thinking of all the electronics, computer, etc.
I might better hire an electrician. I have no idea about how many volts needed.
No wonder the Boss didn't want to touch my girl cave project!
Old 03-27-2010, 05:19 PM   #5
Xtreme DIY'r
Volts are easy...120v unless you have something that runs at 240v
I've yet to see a US TV or PC that requires 240v (some are switchable)
Watts & Amps is what you need to be concerned with
Usually you allow 5a for a computer (600w)
My 42" LCD TV uses just over 105watts
Stereo may use 200w
So you might have 950w Max depending upon your devices
You would need to know what else is on the exisitng circuit
You should verify this before an electrician comes in
Determine what lights & other outlets are on the same circuit
What size breaker serves the circuit - 15a (1800w) or 20a (2400w)
Determine if you have an open slot in your breaker panel in case you need to add a circuit
Then at least you will be able to tell the electrician what you have & may possibly want
Getting an electrican around here to install just an outlet can be difficult
Some may charge a Min $100 charge...more if they need to run a circuit
Depending upon the room it may need to be AFCI protected - that's ~$35 right there
Old 03-27-2010, 06:45 PM   #6
Let's hope if you are performing electrical work Dave you aren't in wet gear.
Thanks Dave. I might just ask Lowe's who they recommend to come out. I'm wanting this space in operation soon.
If I do some before and after pics, where do I post them? I can post them in this thread, I suppose, but it's pretty much renovating the extra bedroom----not only the closet. Thanks again Dave.
(one post left to go DM!!!)
Old 03-27-2010, 06:51 PM   #7
Xtreme DIY'r
You can always add a power strip if you need to plug more items in
Its not how many outlets you need, its how much power
If the closet is small I'd only install one outlet
I have one in a closet where I originally had our router & cable modem
The outlet is no longer used as everything was moved to the basement
Old 03-27-2010, 06:58 PM   #8
Yeah, I'm using a power surge now in this room. I'll use it in there.
I'm hoping once the electrician comes in he can easily put in the outlet. I'm with you in thinking this will be easy if the cutout that the cable was put can easily be made to an outlet too. We will see. Like I said, "what do I know?" but I also know the Boss will exaggerate. He thinks this will discourage me, but it only makes me more determined! But, he probably knows this too!
Old 03-27-2010, 08:47 PM   #9
Military Mom of 4
Snav's Avatar
You can forgo a lot of expense (in regard to hiring a pro) and get a power-strip that looks spiffy and can attach permanently to your wall - like Erope or Power Squid.
It's always ill advised to plug expensive electronics into standard outlets unless they are a safety which will shut off/trip on it's own (instead of relying on your fuse to do it) in case of a surge during a storm or something.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-27-2010, 09:15 PM   #10
Do they make them cordless now? I really don't want to run a line to the closet from across the room.
COOL! (I just googled that! http://images.google.com/images?hl=e...er+sq&gs_rfai= ) Those are cool. I saw one not too long ago and forgot about them. I don't know. That might not be a bad idea to just get the white one and use it. Thanks Snav!
Old 03-27-2010, 09:34 PM   #11
Xtreme DIY'r
I have our 42" LCD TV plugged into a UPS
Old 03-27-2010, 09:43 PM   #12
In that case, it's time to empty the closet and get it painted. Then it's figuring out what kind of wood to use for the shelves. I think I'm going with a light oak. I actually think I can do this sorta thing myself.
Maybe!
Old 03-27-2010, 10:48 PM   #13
Military Mom of 4
Snav's Avatar
You can do anything you want! Your crafty brain is your orchard!
Old 03-28-2010, 12:42 AM   #14
jlhaslip's Avatar
Take the cover off the receptacle in the Living room to see how many wires are in there.
Are there empty holes to add more wires? Might be an easy task to pull another wire if there are no studs in the way, assuming the circuit isn't 'busy' elsewhere. Have you checked what else is on the circuit yet?
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-28-2010, 10:34 AM   #15
Military Mom of 4
Snav's Avatar
They DO sell outlets that are self-tripping in the case of an overload and so forth so installing one by branching off the nearby outlet isn't out of the question . . . but they are sensitive . . . so more than a set of two would be smart.
It's not complicated and you can pull it off quite nicely if you want to avoid extensions!
How to Fix Electrical Outlets That Don't Work limitdiy Electrical 11 08-08-2009 10:44 PM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 03:06 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 10:28 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
