Electrical Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 07:10 PM   #1
electrical outlets
how do i convert a wall outlet to not be controlled by a switch
novicesmith is offline   Reply With Quote
Old 02-12-2011, 08:10 PM   #2
Rewards Points: 324
simplest way,turn off power to ckt.remove sw from box,wire nut the two wires that are on the switch together.in case you want to use the switch again,mark the wires.you can get a blank cover or just leave switch in box.
oleguy74 is offline   Reply With Quote
Old 02-12-2011, 08:19 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
be aware though that often times it is a code requirement to have a switched outlet. Bypassing the switch would cause the installation to be a code violation.
Help with electrical outlets? peasantgirl Electrical 21 10-18-2010 10:35 AM
Cutting drywall for electrical outlets. Mark Harvey Building & Construction 2 03-24-2010 09:31 PM
How to Fix Electrical Outlets That Don't Work limitdiy Electrical 11 08-08-2009 10:44 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 10:28 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
