Old 08-11-2008, 09:26 PM   #1
electrical outlets
I am replacing an existing electrical outlet. It is back wired. How do I get the existing wires out of the back of the outlet so I can remove it?
Dougie is offline   Reply With Quote
Old 08-11-2008, 09:39 PM   #2
Send a message via AIM to theatretch85
electrical outlets
Usually with a small flat blade screw driver or by just cutting the wires and stripping them new. I find its just easier to cut the wires and start new.
theatretch85 is offline   Reply With Quote
Old 08-12-2008, 01:17 AM   #3
electrical outlets
Dougie, Just above (below?) where the wires are "back-stabbed" into the outlet is a slot. Insert a small screwdriver tip or romex staple (bent into an "L" shape) and that should relieve the pressure and allow the wire to be set free. Like theatretch83, I usually just snip them off and start over. Much easier. pete
petey_c is offline   Reply With Quote
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 10:28 AM
Electrical outlets and Granite backsplash, how? section8 Remodeling 6 01-08-2007 07:55 AM
Can a diyer install electrical outlets? yummy mummy Building & Construction 12 12-23-2006 07:54 PM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
