Electrical Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 10:18 AM   #1
Electrical Outlets
I am dividing my basement to make a small family room. I want to run a new circuit to the breaker box. should I use 14/2 or 12/2 wiring and what kind of outlets should i install. going to run 4 outlets only, no lights or switches, they are allready installed. running a tv and a couple of lights. no heavy loads.
rolly52 is offline   Reply With Quote
Old 10-23-2011, 10:44 AM   #2
Rewards Points: 204
Running 14/2 will allow for a 15 amp breaker. 12/2 a 20 amp breaker. I would run at least two cables even if you only use one. That way it will be present should you require more power.
Some like to put entertainment systems (TV's) on their own circuit. You may want to consider this.
Help with electrical outlets? peasantgirl Electrical 21 10-18-2010 09:35 AM
Cutting drywall for electrical outlets. Mark Harvey Building & Construction 2 03-24-2010 08:31 PM
How to Fix Electrical Outlets That Don't Work limitdiy Electrical 11 08-08-2009 09:44 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 09:28 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
