Electrical Outlet In Upper Wall Corner - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 09:27 PM   #1
Question
Electrical outlet in upper wall corner
Is it against code to install an eletric outlet in the upper wall corner, maybe 6-10" from the ceiling? I am finishing a small bedroom in my basement and would like to mount a small TV into one of its corners. Of course it needs power, so I'd like to install an outlet up there.
I would like to do the same in another bedroom, however it has a vaulted ceiling and a closet which doesn't extend all the way up to the ceiling (so the closet has its own "ceiling"). I'd like to install this outlet on the wall above this, only a few inches above the closet's "ceiling". Would this be against code?
Of course, both need to be on AFCI circuits (it's a brand new home), since they're bedrooms. So, for the existing bedroom I could only branch off the light if that is on an AFCI (I haven't checked). Or should I avoid adding it to the existing circuit and rather pull a new wire and add it to the new circuit I'm adding for the bedroom in the basement?
TomU is offline   Reply With Quote
Old 01-05-2012, 09:49 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by TomU View Post
Is it against code to install an eletric outlet in the upper wall corner, maybe 6-10" from the ceiling? No; it isn't.
Of course, both need to be on AFCI circuits (it's a brand new home), since they're bedrooms. Correct
TV's, oscillating fans, all sorts of things can go up high.
Having power there is convenient.
Old 01-05-2012, 10:39 PM   #3
Rewards Points: 6,652
Why would it? It is done that way all of the time for whatever equipment may go up there. Ever gone into a bar or restaurant that has signage hanging in their windows? Look up towards the ceiling sometime.
Old 01-05-2012, 11:15 PM   #4
joed's Avatar
Rewards Points: 11,548
You can mount receptacles any place you like except near water where special rules apply. In the wall up high, down low, in the ceiling, in the floor are all valid locations.
Old 01-05-2012, 11:17 PM   #5
Rewards Points: 582
if thats where your tv is that where your plug should be also...yes it ok..
Old 01-05-2012, 11:24 PM   #6
Rewards Points: 12,808
May want to make it a double outlet that way you can add DVD, sound system whatever.
Old 01-06-2012, 08:02 AM   #7
Rewards Points: 1,418
You can put additional receptacles anywhere but they might not count towards the six/twelve foot receptacle spacing rule. (A 6 foot cord emerging from the base of a floor lamp might not reach except perhaps from a very limited range of lamp positions against the wall.)
Old 01-06-2012, 10:01 AM   #8
Thanks everybody. Yeah I had a feeling it wouldn't be a problem, just wanted to make sure
Old 01-06-2012, 10:10 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
To expand on this…a receptacle mounted more than 5-1/2 feet above the floor doesn’t count towards the required wall receptacles (the 6-foot rule).
Kyle
Old 01-06-2012, 10:13 AM   #10
Interesting. It however still counts towards the total load/number of receptacles on the circuit, right? In which case I'd have to figure this out for the existing bedroom...
Old 01-06-2012, 10:15 AM   #11
Licensed Pro
That's only a problem if you're in Canada.
Old 01-06-2012, 10:16 AM   #12
MarginallyQualified
if such calculations applied to residential work
Old 01-06-2012, 10:19 AM   #13
I'm in the US. So you're saying all I have to do is connect the outlet to the room's light and call it done? I mean "I" know that there's only going to be a small load connected to it...
Old 01-06-2012, 10:29 AM   #14
Electrician
SD515's Avatar
Rewards Points: 504
Usually it’s not a problem, but yes you need to take the entire circuit load into consideration.
Kyle
Old 01-06-2012, 10:35 AM   #15
Electrician
SD515's Avatar
Rewards Points: 504
Just for starters....
210.11 Branch Circuits Required.
(A) Number of Branch Circuits. The minimum number of branch circuits shall be determined from the total calculated load and the size or rating of the circuits used. In all installations, the number of circuits shall be sufficient to supply the load served. In no case shall the load on any circuit exceed the maximum specified by 220.18.
Kyle
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Which box for flush-mount (in-wall) outdoor electrical outlet? plambert Electrical 2 10-27-2011 04:05 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 09:16 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 11:30 PM
