Electrical Outlet Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2005, 09:42 AM   #1
I recently had all my GFCI outlets stop working following a snow/rain storm. The circuit uses a GFCI circuit breaker. It wasn't tripped. I switched the breaker off and back on, but the outlets still didin't work. I then replaced the breaker, but the outlets still don't work.
FYI, I had XMas lights plugged into one of the GFCI outlets outside during the snow/rain storm.
Any thoughts?? Thanks.
McRier is offline   Reply With Quote
Old 12-19-2005, 10:35 AM   #2
I might try unpluging everything from that circuit. If that can't reset it i would try disconnecting the xmas light receptical, capping the wires off, and see if you can reset. HS.
K2eoj is offline   Reply With Quote
Old 12-19-2005, 11:05 AM   #3
Thanks for the reply. I had already unplugged everything within the line. Also, the breaker never actually tripped. I can and have reset it.
Old 12-19-2005, 12:33 PM   #4
There is probably a lose wire somewhere in the circut possibly.The best thing to do is purchase a "bug eye" outlet tester.Perferably one that can test GFCI's as well and use it to test the circuts.
donkey is offline   Reply With Quote
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 08:18 PM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 06:23 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
Perplexing electrical problem prglor Electrical 4 05-30-2007 02:20 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
