-   -   Electrical Outlet Problem (http://www.diychatroom.com/f18/electrical-outlet-problem-1485/)
McRier 12-19-2005 09:42 AM
I recently had all my GFCI outlets stop working following a snow/rain storm. The circuit uses a GFCI circuit breaker. It wasn't tripped. I switched the breaker off and back on, but the outlets still didin't work. I then replaced the breaker, but the outlets still don't work.
FYI, I had XMas lights plugged into one of the GFCI outlets outside during the snow/rain storm.
Any thoughts?? Thanks.
K2eoj 12-19-2005 10:35 AM
I might try unpluging everything from that circuit. If that can't reset it i would try disconnecting the xmas light receptical, capping the wires off, and see if you can reset. HS.
McRier 12-19-2005 11:05 AM
Thanks for the reply. I had already unplugged everything within the line. Also, the breaker never actually tripped. I can and have reset it.
donkey 12-19-2005 12:33 PM
There is probably a lose wire somewhere in the circut possibly.The best thing to do is purchase a "bug eye" outlet tester.Perferably one that can test GFCI's as well and use it to test the circuts.
