Old 09-04-2009, 09:46 AM   #1
Electrical outlet over Hot water baseboard
What would be my height per code that an outlet needs to be above a hotwater baseboard heater (non electrical baseboard)?
redrumliny is offline   Reply With Quote
Old 09-04-2009, 10:59 AM   #2
Remodeler
adpanko's Avatar
Not entirely sure, but I can tell you my experience and maybe it will help. My first house had old 7" high cast iron baseboard. I placed outlets 12" on center from the floor, and they all passed inspection. So the bottom of the outlet boxes were only about 2-3" up from the top of the radiator, and that was apparently fine.
adpanko is offline   Reply With Quote
Old 09-04-2009, 11:08 AM   #3
7" is about the height of my baseboard and I was planning on 14 to 15" above the floor so that would be a 7" to 8" clearance in my case. I did see that it was against code to put outlets aboce electrical (convection) baseboards that apparently doesn't apply here?
Old 09-04-2009, 06:15 PM   #4
Moderator
Termite's Avatar
Im unaware of any code restrictions on receptacle height or clearance to the baseboard in this circumstance.
Old 09-04-2009, 07:11 PM   #5
Electrical Contractor
kbsparky's Avatar
Originally Posted by redrumliny View Post
.... I did see that it was against code to put outlets aboce electrical (convection) baseboards that apparently doesn't apply here?
There is no specific Code requirement about the placement of electrical outlets above baseboard heaters.
You might be thinking of section 110.3(B) of the Code concerning the use and installation of listed and labeled utilization equipment. By referring to manufacturer's instructions, which prohibit the placement of outlets above such units.
-KB
Old 09-04-2009, 07:11 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
+1
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Electrical Outlet Conversion 230/110 mcbuster Electrical 11 07-20-2009 02:03 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 06:08 PM
