Electrical Outlet Location. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 07:49 PM   #1
electrical outlet location.
location of outlet in single level island cabinets from floor to under the stone?
emg44@att.net is offline   Reply With Quote
Old 12-12-2011, 08:46 PM   #2
jproffer's Avatar
Rewards Points: 702
You're going to have to be a little more specific
jproffer is offline   Reply With Quote
Old 12-12-2011, 08:54 PM   #3
Licensed electrician
Rewards Points: 1,028
Try this:
(5) Receptacle Outlet Location.
Receptacle outlets shall
be located above, but not more than 500 mm (20 in.) above,
the countertop. Receptacle outlets rendered not readily accessible
by appliances fastened in place, appliance garages,
sinks, or rangetops as covered in 210.52(C)(1) Exception,
or appliances occupying dedicated space shall not be considered
as these required outlets.
[ROP 2211a]
Exception to (5): To comply with the conditions speci
fied in
(1) or (2), receptacle outlets shall be permitted to be
mounted not more than 300 mm (12 in.) below the countertop.
Receptacles mounted below a countertop in accordance
with this exception shall not be located where the
countertop extends more than 150 mm (6 in.) beyond its
support base.
Old 12-12-2011, 09:22 PM   #4
I'm trying to put a remodeling outlet box on the side panel of an island cabinet,so what is the correct location of electrical box from the floor to the bottom of the box 20", 24", 28", or?
Old 12-12-2011, 09:30 PM   #5
Master Electrician
Rewards Points: 3,678
You don'tmeasure from the floor. See Jim's post #3.
brric is online now   Reply With Quote
Old 12-12-2011, 09:59 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This is what you type into a search engine.
This is what you ask on a message board with real people answering.
See reply #3.
Which box for flush-mount (in-wall) outdoor electrical outlet? plambert Electrical 2 10-27-2011 04:05 PM
Existing concrete slab has electrical and cat5 outlet. Would like smaller faceplates. noone Electrical 5 10-17-2011 03:29 PM
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 12:08 PM
Tiling around HALF an electrical outlet Patless Electrical 10 10-07-2009 11:39 AM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
