Electrical Outlet Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 08:25 PM   #1
Rewards Points: 396
Electrical outlet issue
hi,
I noticed that my electrical outlet cover plate and outlet itself is very loose so when I removed it I noticed the bottom threaded piece that you fasten the receptacle to is broken off which only left one. I tried removing the entire box so I could replace it with an old work box but its attached to a stud and unless I open up the wall I don't see how I can remove it. Any ideas?
detroittigerfan is offline   Reply With Quote
Old 08-14-2013, 08:34 PM   #2
Electrical Contractor
kbsparky's Avatar
Plastic or metal box?
-KB
Old 08-14-2013, 08:37 PM   #3
Rewards Points: 396
metal unfortunately.
Old 08-14-2013, 09:20 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,102
If you want to avoid having to remove the j box,
Try pop riviting a small metal L bracket in to the box
to replace the broken tab.
dmxtothemax is offline   Reply With Quote
Old 08-14-2013, 09:29 PM   #5
Rewards Points: 396
But wouldn't I need a threaded L bracket?
Old 08-14-2013, 10:15 PM   #6
MarginallyQualified
Rewards Points: 2,464
JB Weld the receptacle in place...
and/or live with it until you have some other reason to go deeper
Old 08-15-2013, 04:14 AM   #7
If you can find the right sized thread tap,
you could make one.
or-
You could just use a self taping metal screw,
And drill the appropriate hole in the bracket.
It might sound like a lot of work,
But it's far easier than removing and replacing a j box.
Old 08-15-2013, 07:24 AM   #8
jbfan's Avatar
Rewards Points: 232
Thread the hole to the next size which is 8/32.
jbfan is online now   Reply With Quote
Old 08-15-2013, 12:42 PM   #9
hi,
... I tried removing the entire box so I could replace it with an old work box but its attached to a stud and unless I open up the wall I don't see how I can remove it...
The experts here can verify this, but I don’t think it’s a hard as you think to remove the old box. I use a heavy work-glove and a hacksaw blade and slip it between the box and the stud. Not very difficult to cut the nails that way. I’ve done quite a few that way.
The experts might not like that way but I believe many people use that method.
p.s. it's been a while lol and now I think - well how did the blade fit inbetween the box and stud? Don't remember the details, but it did work!
agoodboy is offline   Reply With Quote
Old 08-15-2013, 07:34 PM   #10
kbsparky's Avatar
We routinely remove both plastic and metal boxes without having to patch the wall afterwards.
It can be tricky, but we use a sawzall and cut the nails off that holds the box against the stud.
Every blue moon or so I will encounter one with a face bracket instead of side brackets. If that is the case, we cut the bracket off the box, leaving it in place under the drywall/plaster.
Once the old box has been removed, we simply install a new plastic box fastened with drywall screws through the side of the box into the stud.
IF your place has metal conduits instead of flexible cable then you might just have to cut out a large opening in the wall and patch it up afterwards ....
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
agoodboy (08-15-2013), Philly Master (08-16-2013), ToolSeeker (08-18-2013)
Old 08-17-2013, 10:20 AM   #11
Rewards Points: 170
I recently had to remove a metal outlet box in order to run a new wire down the wall to add a second outlet at the end of a peninsula in a kitchen. In order to remove the box I took a keyhole saw, with the power off, and cut the nails holding the box onto the stud. once this was done I was able to pull the box out, slowly letting the wires out of the box. Then, once the new wire was ran, feed all wires into old work box and install new box in wall. You would never even know it was done. good luck on your project
diyer111 is offline   Reply With Quote
Old 08-17-2013, 10:24 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You know that is a code violation (Ive done it myself)
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-17-2013, 04:14 PM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They make smart boxes for this application.
Old 08-17-2013, 04:23 PM   #14
A "Handy Husband"
rjniles's Avatar
Exactly, and home made ones don't count.
Old 08-17-2013, 08:32 PM   #15
Rewards Points: 4,792
It's not difficult to remove old metal boxes by using a reciprocating saw and metal blade to cut through the nails. A mini-hacksaw would work too of course.
jeffnc is offline   Reply With Quote
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Installing Electrical Outlet in the place of an old Light Fixture Mikon8er Electrical 20 11-08-2011 10:23 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 08:59 PM
