Electrical Outlet Hook Up. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 07:00 PM   #1
Electrical outlet hook up.
Hi Guys, I am running a few outlets along a wall in the basement. The bx runs from panel to 1 st outlet, and then bx from that outlet to the other outlet so fourth. My question is which is the propoer way to wire the outlet, I know hot goes to gold and white to silver. But in the box where you have two sets of bx wires, do you pigtail and then connect to the outlet, or do you just connect directly to the outlet, one side one pair, and the other side the other pair? Thanks
helpless handyman is offline   Reply With Quote
Old 07-30-2007, 07:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Either way. I pigtail, but it works both ways.
Old 07-30-2007, 07:43 PM   #3
Electrician
Rewards Points: 802
That is like qasking what came first the chicken or the egg. There are arguments for both and they are both acceptable to code.
Just don't backstab them, backstabbing is a very evil thing. Take the extra 3 minutes and put the wires under the screw.
darren is offline   Reply With Quote
Old 07-30-2007, 07:48 PM   #4
joed's Avatar
Rewards Points: 13,344
No pigtails unless you have more than 2 wires. Wires nut cost money, add another point of failure, take up space and in Canada must be counted in box fill calculations.
Old 07-30-2007, 08:18 PM   #5
Thanks to all, I will then screw them Just wanted to know what was code..
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 06:23 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
How to replace an Electrical Outlet daverose31 Electrical 6 06-27-2007 12:22 AM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 10:18 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
