Electrical Outlet Depth For Tile Backsplash - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 02:58 PM   #1
Electrical outlet depth for tile backsplash
We completely gutted a kitchen and plan to do tile backsplash. What depth should we place the new outlet boxes out from the wall studs so that we won't have to move them out after sheetrock is complete?
suzy5033 is offline   Reply With Quote
Old 08-29-2010, 03:05 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
an amount equal to the thickness of the tile being used.
it's better to be a little recessed than sticking out a bit so do not be generous with the dimension of the outset.
and yes, as jim said in the following post (and I simply assumed you would figure you already had to set it out for the rock but upon retrospect, it might not have been totally clear), be sure to include the thickness of the 'rock when calculating the outset.
Old 08-29-2010, 03:08 PM   #3
Licensed electrician
Rewards Points: 1,744
You need to figure the thickness of your drywall and the tile. You could use adjustable boxes to make sure you get the right depth. A little more expensive, but worth it IMO. You could also use the SmartBox that lets you adjust the depth after the tile is installed.
The box can set back no more than 1/4" from a non-combustible surface. I think you will find that that leaves too much play when plugging something in.
Old 08-29-2010, 03:12 PM   #4
nap
You talking to me?
nap's Avatar
unless it is plastic tile, neither the tile not sheetrock is considered to be flammable. If the box is inset too far, there are means to shim the recep so they mount solidly to the box.
Old 08-30-2010, 06:07 AM   #5
47_47's Avatar
Rewards Points: 62
I would install a Carlon adjustable box.
47_47 is offline   Reply With Quote
Old 08-30-2010, 09:28 AM   #6
Rewards Points: 320
I would use either adjustable boxes or 4x4's with the proper depth plaster ring to account for the wallboard and tile.
teamo is offline   Reply With Quote
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 08:51 PM
Securing Electrical Outlet in Unfinished Room - Cement smohamed9 Electrical 2 04-04-2010 08:53 AM
Need to sink existing outlet boxes for new backsplash Stcrosby Electrical 14 02-08-2010 07:31 PM
How to install an Electrical Outlet in the basement Riley W Electrical 2 07-30-2009 02:51 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
