Electrical Outlet For Counter Top - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 10:41 AM   #1
Electrical Outlet for Counter top
I would like to add an electrical outlet to a kitchen island counter top. To meet code, I know I can lay it down flat even it is raised above the top of the counter. The counter top is wood, cherry, and we don't use it to cut on.. mostly to place teh dishes and such. Any suggestions?
Thank you
Andysc is offline   Reply With Quote
Old 09-27-2009, 10:55 AM   #2
Rewards Points: 168
Buy a "cut in box" along with a cherry wood cover plate. They are sometimes called "old work" boxes. Curious, why on top?
If it worked before you worked on it. You did something wrong.
Old 09-27-2009, 12:18 PM   #3
Thank you
You mean you know you can't lay it down flat ?
406.4 E
Receptacles in Countertops and Similar Work Surfaces
in Dwelling Units.
Receptacles shall not be installed in a face-up position in countertops or similar work surfaces.
There are recessed outlets that will pop-up that have outlets on the side
Very expensive
Old 09-27-2009, 07:28 PM   #4
Rewards Points: 1,016
Common sence seems to dictate one would not want a electrical outlet facing upwards in a countertop. There must be somewhere else you can mount it on the side of the island?
Old 09-28-2009, 09:07 AM   #5
joed's Avatar
Rewards Points: 12,924
You may need a mounting box called a tombstone.
Old 09-28-2009, 02:57 PM   #6
WaldenL's Avatar
Rewards Points: 268
You could probably use something along the lines of http://www.rockler.com/product.cfm?page=11109, never thought to try it in a kitchen. However, they are very expensive for what that do. As JV said, why on top? Normal treatment would be to put it on the side of the cabinet under the island.
WaldenL is offline   Reply With Quote
Old 09-28-2009, 05:42 PM   #7
You could mount this underneath the countertop maybe?
http://www.wiremold.com/diy/products/plugmold.asp
JonboyAU is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Installing a new in-line electrical outlet Nedly83 Electrical 5 09-01-2009 07:44 AM
Electrical Outlet Conversion 230/110 mcbuster Electrical 11 07-20-2009 01:03 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 08:18 PM
