Electrical Outlet In Condo Concrete Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 06:27 PM   #1
Electrical outlet in condo concrete floor
I want to install a couple of electrical outlets in our condo concrete floor. I will be installing 1/2 inch click lock engineered hardwood. Can I cut a grove in the bottom of the hardwood to run the electrical cable?
lewking is offline   Reply With Quote
Old 11-17-2012, 06:57 PM   #2
Rewards Points: 6,652
Nope, will not happen, unless you use something like http://www.southwire.com/products/Fl...ctricalOEM.htm
This is their other site that explains its use better http://www.flatwireready.com/
Only problem is, right now Southwire does not offer 120vac option in their new product line for this. Another option that is available http://www.ampnetconnect.com/documen...n_Rev4_Web.pdf
Old 11-17-2012, 07:47 PM   #3
Rewards Points: 216
what floor are you on ? flexi-core ?
Fix'n it is offline   Reply With Quote
Old 11-18-2012, 11:03 AM   #4
Rewards Points: 78
I am sorry, but you are in for trouble as far as the floor and the ceiling in most condo's. I built these things (condo's) back home in Florida and the only access you will have is in the interior walls. But, you have no ceiling or floor access to access the walls either. This the norm with concrete structures.
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 08:28 AM
Electrical outlet against concrete bphyatt Electrical 0 02-25-2010 10:34 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 10:52 PM
