Electrical Outlet & Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 06:49 PM   #1
Smile
Electrical outlet & Ceiling fan
Hello everyone
I would like to add an extra power outlet on the same wall with constant power and a ceiling fan that is switched on & off at the switch.
The wall has a half switched outlet the bottom is switched and the top one constant. http://yfrog.com/egwiringp here is a schematic of the wiring. Its not the best drawing but at least you get the idea
I appreciate any help with this project
mike-ee is offline   Reply With Quote
Old 04-28-2009, 07:33 PM   #2
dSilanskas's Avatar
Its very simple. You will need a mulit meter to figure out what wire is the hot in the switch box. Run a 14/2 romex from the switch box to whatover outlet your added. The white from in the switch box will splice with the white from the new wire you have added. Now youneed to fiure out what wire is the hot wire in the switch box. That will be where you will pull the power from for the new outlet. Just splice those wires together and add a little pig tail to go back onto the switch.
dSilanskas is offline   Reply With Quote
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
Bulhead Conceiled Electrical Outlet rayignacio Electrical 5 02-08-2009 02:52 PM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 10:42 PM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 06:00 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
