Old 07-03-2011, 01:19 PM   #1
Electrical outlet boxes
It's stiffling in my upstair office and I have several ceiling fans that I want to put up as well as a new bathroom light fixture but.....
I discovered there's no outlet boxes in the ceilings, just a scimpy metal bar which the wiring hasn't been secured to and I was wondering if anyone out there knows what the code says is required (Ontario Canada). I'm in a high-rise of two-story townhouse units and it's all concrete.
As well, I've got a Harbor Breeze universal ceiling fan & light remote but have lost the instructions for the installation and would appreciate some direction and also do I just plop the receiver into the canopy or what?
thanks
seymour is offline   Reply With Quote
Old 07-03-2011, 01:25 PM   #2
Licensed electrician
The first thing to determine is if the current box and brace are rated for fan support. If the answer is no then those changes will need to be made first before you attempt to wire the fan.
Old 07-03-2011, 01:40 PM   #3
Thanks Jim! When I took a look at the little 'bar-thing' that was the first thing I though of, there's no way they'll hold the weight let alone the vibration of the fan and there is NO BOX, just the conduit tubing with the wires inside floating loose inside the wall with the wiring running thru a hole in the 'bar-thing'. Will speak with Building Standards and the Property Manager about getting an electrician in to install the boxes -- so much for the place being 'professionally renovated' ??!!!
Old 07-03-2011, 01:52 PM   #4
Can you post a pic? Someone might be able to offer some options after seeing what you are dealing with.
Old 07-03-2011, 04:00 PM   #5
sorry, unable to post pix and friend has told me that outlet boxes are code here so will follow up with building standard people.
thanks again!
Electrical outlet not working. JohnDF Electrical 3 01-05-2011 11:40 AM
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 12:08 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 08:59 PM
