Old 09-29-2012, 03:46 PM   #1
Electrical outlet
I have an outdoor non GFCI (protected before this outlet in the circuit) outlet. It has 2 black/2white and ground wires, I want to add an outlet farther doown the house from this outlet so there will be 3 blacks/3whites and ground. What is the best way to hook these wores up/ Thanks
nickhub is offline   Reply With Quote
Old 09-29-2012, 04:09 PM   #2
Electrical outlet
Nick,call an Electrician.
bobelectric is online now   Reply With Quote
Old 09-29-2012, 05:42 PM   #3
Electrical outlet
Pigtail the wires, or put 3 under the receptacle.
AltaSparky is offline   Reply With Quote
Old 09-29-2012, 06:23 PM   #4
DIY Enthusiast
sublime2's Avatar
Electrical outlet
You could leave current receptacle as is and back stab the 3 rd white and black.of course twist all grounds together.
sublime2 is offline   Reply With Quote
Old 09-29-2012, 06:54 PM   #5
Licensed electrician
Electrical outlet
If this is a 120 volt 15 or 20 amp receptacle the OP needs to install GFI protection.
Old 09-29-2012, 08:44 PM   #6
DIY Enthusiast
sublime2's Avatar
Electrical outlet
OP states he has GFCI in the circuit prior to this outlet.
Does that not provide the protection or is it because it is outside it needs to be a GFCI regardless?
Old 09-29-2012, 09:07 PM   #7
Electrical outlet
His receptacle is already GFI protected.
Old 09-29-2012, 10:19 PM   #8
Electrical outlet
Sorry for the confusion. I read it as non-GFI protected, not non-GFI (protected upstream).
As long as it is wired from the LOAD terminals of the GFI it would be fine.
Old 09-30-2012, 12:44 PM   #9
Electrical outlet
It is my understanding that only one wire per each screw on the outlet is allowed. I have seen on another site where the wiring was to pigtail all 3 wires and then only attach the one pigtail to the outlet. Grounding i understand. Is it OK to pigtail from outlet to 2 of the wires (ie 2 black, 2 white) and put the other (1 black, 1 white) directly on the other screws on the outlet?
Thanks for your help
Installing Electrical Outlet in the place of an old Light Fixture Mikon8er Electrical 20 11-08-2011 10:23 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Grounded Electrical Outlet? jaymank21 Electrical 7 09-08-2010 06:40 PM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 05:38 PM
