Electrical outlet
993 views 8 replies 5 participants last post by  nickhub
I have an outdoor non GFCI (protected before this outlet in the circuit) outlet. It has 2 black/2white and ground wires, I want to add an outlet farther doown the house from this outlet so there will be 3 blacks/3whites and ground. What is the best way to hook these wores up/ Thanks
#8 ·
Sorry for the confusion. I read it as non-GFI protected, not non-GFI (protected upstream).
As long as it is wired from the LOAD terminals of the GFI it would be fine.
#9 ·
It is my understanding that only one wire per each screw on the outlet is allowed. I have seen on another site where the wiring was to pigtail all 3 wires and then only attach the one pigtail to the outlet. Grounding i understand. Is it OK to pigtail from outlet to 2 of the wires (ie 2 black, 2 white) and put the other (1 black, 1 white) directly on the other screws on the outlet?
Thanks for your help
