Electrical Outles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 11:58 PM   #16
JuzRick's Avatar
Originally Posted by eefromjersey View Post
o.k., changed the outlet and no luck, i will be contacting an electrician. If anyone can just tell me what to expect, tearing into walls? Etc... Just want to brace myself.
Thank you,
even thou its not common for homes to have dedicated circuits for high rated appliances/items. It is now code for you to install dedicated circuits for such appliances/items that can cause a overload sharing on a circuit which can over exceed the ampere.
I suggest you call a electrician.. For it sounds to me that you could very well be exp. Breaker issue, or a short/arching somewhere in the circuit. Specially if all neutral, grounds are not securely tighten to the terminals in the service panel.
JuzRick is offline   Reply With Quote
Old 11-24-2012, 01:48 AM   #17
JuzRick's Avatar
ee: it could possibly be something totally different too. Hey, thats why in this trade pacifically it is called a practice.. for in allot of cases one common thing can sound as if its a related issue- but totally something new never witness before. We shall see the after results!
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
