Electrical In New Addition Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 10:15 AM   #1
Electrical in new addition question.
How many 20amp outlets typically can you run off one 20amp circuit w/ 12-2. Area consist of foyer and master bedroom. (Will this pass a final insp. Location: St. CLAIR County MI.
Also can one 14amp circuit (GFI) Pass insp for all outlets lights and heat/fan for a master bathroom?
Fragle is offline   Reply With Quote
Old 03-24-2011, 11:51 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
The average is 10, but the code allows as many as you want.
You can not use #14 for a bath.
That is required to have a 20 amp circuit.
The heat/fan may be required to be on a seperate circuit.
Old 03-24-2011, 01:48 PM   #3
You cant have as many outlets you want on a circuit, thats like telling people put 20 outlets on a citcuit. You need to keep at 10-12 per circuit with a few lights on a circuit as well. Also tha bathroom you need 12/2 circuit for your outlets, you can use 14wire in a bathroom for your switches,lights,standard bath fan. As for your combo bath fan you need a dedicated 12/2 circuit and also individual 12/2 switch legs for each fan function.
jerseystyle26 is offline   Reply With Quote
Old 03-24-2011, 02:35 PM   #4
I=E/R
a7ecorsair's Avatar
OK, give us the NEC reference for this requirement.
a7ecorsair is offline   Reply With Quote
Old 03-24-2011, 02:43 PM   #5
Ok fine put as many as you want and never have the circuit work, There is no code for how many outlets on a circuit, but tha nec does give you basic calculations for how many should be on a circuit. Do tha math code gives you tha equation.
Last edited by Gary in WA; 03-24-2011 at 10:59 PM. Reason: name calling is against forum rules
Old 03-24-2011, 03:12 PM   #6
Master Electrician
Rewards Points: 3,756
Totally false for dwelling units. Get your facts straight.
brric is offline   Reply With Quote
Old 03-24-2011, 03:17 PM   #7
Whats false? Obviously you didnt catch my sarcasm bud. Go back and read the previous posts before you try and input your comments.
Old 03-24-2011, 03:22 PM   #8
Master Electrician
180 Va calculations for receps only apply to commercial and industrial installations, not dwelling units. Cite the code equation.
Old 03-24-2011, 03:40 PM   #9
Yea bud your wrong. Code 220.3 for dwelling units(homes,ect.). Look it up, id type it for you but im on a phone and have no type and paste available
Old 03-24-2011, 04:12 PM   #10
Master Electrician
220.3 deals with calculations. It has nothing to do with how many receps are allowed on a dwelling unit circuit.
Old 03-24-2011, 04:32 PM   #11
Calculations for circuits and how to figure how much they draw, therefore you could put two and two together and figure out how much you can put on a circuit depending on what if and how much load is on an outlet. Dude its all right there. Are you saying you like to overload the circuits? I know I dont go over 10 things a piece on a circuit. Sometimes less if theres heavy loads projected on a circuit.
Old 03-24-2011, 04:55 PM   #12
Master Electrician
Please tell me how you can calculate the load on a general purpose circuit. If there is a circuit with 20 recptacles on it, and nothing is plugged into the receptacles, what is the load?
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 08:10 PM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 09:03 AM
ugh, very simple electrical question - installing ceiling light diy'er on LI Electrical 6 02-16-2010 11:23 AM
a question Mexico electrical question stanlam Electrical 2 02-01-2010 10:27 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 01:59 PM
