Electrical Lights Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 01:42 PM   #1
Question
Electrical lights problem
During a thunderstom Tuesday night I flipped off a light switch to the kitchen and at the same time the lights in the living room went out and we then checked the rest of the house and only have lights in some rooms. We have power to all our plug ins and all appliances work. We have checked the breaker boxes, nothing blown. Replaced a few light switch boxes and that did not help. Any suggestions?
swalz is offline   Reply With Quote
Old 03-21-2012, 02:44 PM   #2
Rewards Points: 1,512
Check the voltage (hot to ground) at the circuit breakers.
Are you getting the full 120 volts at each?
Are you getting 240 volts from hot to hot at the big lugs at the top of the breaker box?
Where one incoming branch circuit cable has red and black wires going to two different breakers, do you get 240 volts between those two breaker screws?
Old 03-22-2012, 07:11 AM   #3
The reply immediately preceding has been reported as advertising spam.
Yes you have an added measure of safety if you turn off you main breaker when there is a thunderstorm.
But hardly anyone does that because it is still handy to have power on for lights, etc. and also it is inconvenient to reset clocks, VCRs (DVRs), etc.
I can never get digital clocks reset right, typically it ends up 45 to 90 seconds fast or 45 to 90 seconds slow. While I have your attention, can you give me some hints on how to get them set more accurately?
Problem with Christmas lights burning out asugrads Electrical 21 12-20-2011 02:28 PM
Dimming Lights and Possible Neutral Problem carfan87 Electrical 26 12-19-2011 06:54 PM
Strange Electrical Problem pete0403 Electrical 7 08-14-2011 05:56 PM
2002 Pontiac Grand Prix Electrical Problem bipper Automotive Repairs 5 07-06-2009 11:06 AM
Recessed Lights problem Boycer88 Electrical 15 02-01-2009 07:23 PM
