Electrical Light Circuit Crossed With Recept Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 11:24 AM   #1
electrical light circuit crossed with recept circuit
I plug in a vacuum and the lights come on in ding room. Also other receptacles dont work. Where do i start.
shakydoctor is offline   Reply With Quote
Old 01-01-2013, 11:36 AM   #2
Rewards Points: 240
Sounds like a floating neutral. Do you have lights that are excessively bright? If so, call your power company right away. This is a dangerous situation.
fa_f3_20 is offline   Reply With Quote
Old 01-01-2013, 11:45 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Loose connection from that receptacle to down stream receptacles.
Wiggle the plug with the vac plugged in and see if the light flickers.
Old 01-01-2013, 11:53 AM   #4
Licensed electrician
Rewards Points: 1,502
Originally Posted by jbfan View Post
loose connection from that receptacle to down stream receptacles.
x2 ..............
Old 01-01-2013, 12:07 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
....x3
Old 01-01-2013, 12:08 PM   #6
Rewards Points: 240
You guys are probably right. I jumped to a conclusion based on the OP's "other outlets don't work" statement.
Old 01-01-2013, 01:03 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
When someone makes a post like the OP and asks "Where do I start?", my first impression is to say "Call an electrician".
We know nothing of the OP's capabilities, experience or tools/testing equipment.
shakydoctor, can you tell us a bit more about this situation and your level of expertise?
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
shakydoctor (01-01-2013)
Old 01-01-2013, 08:43 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,190
Has someone wired an recepticule into a switch loop ?
bad neutral also poss'
Loose connecttion somewhere ?
Unless it's something simple like a loose wire
then it's not really something for a novice to fix.
Recomend an electricain !
dmxtothemax is offline   Reply With Quote
Pilot light wont stay lit...Circuit problems? Lavid2002 Appliances 3 12-09-2012 03:21 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
Toe kick electrical, which circuit? langless28 Electrical 4 10-17-2012 05:48 AM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 09:32 PM
