-   -   electrical light circuit crossed with recept circuit (http://www.diychatroom.com/f18/electrical-light-circuit-crossed-recept-circuit-167933/)
shakydoctor 01-01-2013 11:24 AM
I plug in a vacuum and the lights come on in ding room. Also other receptacles dont work. Where do i start.
fa_f3_20 01-01-2013 11:36 AM
Sounds like a floating neutral. Do you have lights that are excessively bright? If so, call your power company right away. This is a dangerous situation.
jbfan 01-01-2013 11:45 AM
Loose connection from that receptacle to down stream receptacles.
Wiggle the plug with the vac plugged in and see if the light flickers.
Jim Port 01-01-2013 11:53 AM
Originally Posted by jbfan (Post 1083947)
loose connection from that receptacle to down stream receptacles.
x2 ..............
Stubbie 01-01-2013 12:07 PM
....x3
fa_f3_20 01-01-2013 12:08 PM
You guys are probably right. I jumped to a conclusion based on the OP's "other outlets don't work" statement.
Speedy Petey 01-01-2013 01:03 PM
When someone makes a post like the OP and asks "Where do I start?", my first impression is to say "Call an electrician".
We know nothing of the OP's capabilities, experience or tools/testing equipment.
shakydoctor, can you tell us a bit more about this situation and your level of expertise?
dmxtothemax 01-01-2013 08:43 PM
Has someone wired an recepticule into a switch loop ?
bad neutral also poss'
Loose connecttion somewhere ?
Unless it's something simple like a loose wire
then it's not really something for a novice to fix.
Recomend an electricain !
