Electrical LBs - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 10:31 PM   #1
Rewards Points: 175
Electrical LBs
Hello, can anyone tell me the difference between a mogul LB and a regular LB and why you would use one over the other... Or advantages and disadvantages?
Thanks!
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 08-23-2012, 11:14 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Moguls are wire pulling elbows for RMC and IMC. They generally have more cubic inches of volume and you rarely see them used except where service entrance conductors enter a building. Some even have rollers in them to help when pulling the wire.
Old 08-24-2012, 08:15 AM   #3
Rewards Points: 175
Thanks for the reply.
Thats what I'm doing, new service, using 2" rigid. I see some of my neighbors have regular LBs. Is it "easier" to pull using the mogul?
Old 08-24-2012, 08:46 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Yes ... larger wire sizes that are common to service entrance conductors will pull easier and there is a bigger 'hump' for lack of a better word on the Lb to allow for the bend of the wire when you close the access panel.
Old 08-24-2012, 09:22 AM   #5
Rewards Points: 175
Awesome! Thanks for the info!
Old 08-24-2012, 11:17 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
And they are a lot more expensive that regular LBs
Coastal South Carolina
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
