Electrical In Laundry Shute - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 07:18 PM   #1
Rewards Points: 150
The previous owner of my house had part of the basement on fire which burned up the knob and tube wires going up to the bedrooms and bathroom. He had an electrician come in and put 2 1" pvc conduit lines in the laundry Shute which leads up to the 2nd floor bath closet. One ends in the closet to feed the bath lights and plugs. The other one goes clear up to the attic to feed the three bedrooms and hall. He ran 2-12/3 lines for that. Is it ok to have conduit in a laundry Shute that I still use?
romex1220 is offline   Reply With Quote
Old 07-06-2013, 08:50 PM   #2
jproffer's Avatar
Rewards Points: 714
The way I understand the it, the conductors/cables have to be "protected from physical damage", which they are in the conduit....so I would say it's fine.
One of the pros will be along to let us both know for sure.
jproffer is offline   Reply With Quote
The Following 2 Users Say Thank You to jproffer For This Useful Post:
Kyle_in_rure (07-06-2013), sublime2 (07-06-2013)
Old 07-06-2013, 10:23 PM   #3
Electrical Enthusiast
Rewards Points: 504
There was a post a few weeks back about running power through a laundry chute...I forgot what the "final verdict" was. Like jproffer said, the conduit seems to cover the "physical damage" part. A pro should respond soon.
A fire burned up the old wiring?
Kyle_in_rure is offline   Reply With Quote
Old 07-06-2013, 10:31 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Wouldn't fly in my area.
If your EC would have pulled a permit, you'd know the answer.
Old 07-06-2013, 10:38 PM   #5
Rewards Points: 150
why would it not pass inspection in your area?
RIP EJT
usair is offline   Reply With Quote
Old 07-06-2013, 10:42 PM   #6
Rewards Points: 278
It was my thread regarding laundry chute as a possibility for my upcoming home rewire. If my inspector is ok with it then I will need to close it off such that it could ever again be used as a chute, run conduit, and seal it for fire block at top and bottom with fire rated caulk. But the point was made that it would e excellent for hvac so I'm not sure I will go that route.
dgfit is offline   Reply With Quote
The Following User Says Thank You to dgfit For This Useful Post:
Old 07-06-2013, 10:55 PM   #7
k_buz's Avatar
The best I can give you is that a laundry chute is not a chase for wiring. It is specifically designed for one use. The best code I could cite is that PVC needs to be protected from physical damage as well.
Old 07-07-2013, 07:44 AM   #8
Rewards Points: 150
How much damage could shirts and towels do to PVC? Some local amendments defy logic.
RIP EJT
The Following User Says Thank You to usair For This Useful Post:
Kyle_in_rure (07-07-2013)
Old 07-07-2013, 07:47 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I agree. Unless you are throwing rocks down there I can't see this as any different than pretty much any other area in a residence.
An inspector claiming physical damage is grasping at straws.
Speedy Petey is online now   Reply With Quote
Old 07-07-2013, 08:06 AM   #10
k_buz's Avatar
I don't fully agree...
If some one would put PVC in a laundry chute, how would they strap it? Generally, it wouldn't be strapped so the PVC is just kind of floating in there.
As for the method itself, I would say it is similar to running up a cold air return.
Old 07-07-2013, 08:26 AM   #11
Rewards Points: 278
Everything I have understood says you have to completely disable it as a laundry chute which just makes it a metal lines open wall cavity - basically a cold air return. I guess if you could get the liner out then there would be no need for conduit. But it's horrible for fire cuz it gives a straight shot to all floors. I'm going to avoid it for my runs if I can.
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 08:52 PM
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Angled Laundry Chute Fox Remodeling 10 06-01-2010 11:09 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
