-   -   Electrical in laundry shute (http://www.diychatroom.com/f18/electrical-laundry-shute-183164/)
romex1220 07-06-2013 07:18 PM
The previous owner of my house had part of the basement on fire which burned up the knob and tube wires going up to the bedrooms and bathroom. He had an electrician come in and put 2 1" pvc conduit lines in the laundry Shute which leads up to the 2nd floor bath closet. One ends in the closet to feed the bath lights and plugs. The other one goes clear up to the attic to feed the three bedrooms and hall. He ran 2-12/3 lines for that. Is it ok to have conduit in a laundry Shute that I still use?
jproffer 07-06-2013 08:50 PM
The way I understand the it, the conductors/cables have to be "protected from physical damage", which they are in the conduit....so I would say it's fine.
One of the pros will be along to let us both know for sure.
Kyle_in_rure 07-06-2013 10:23 PM
There was a post a few weeks back about running power through a laundry chute...I forgot what the "final verdict" was. Like jproffer said, the conduit seems to cover the "physical damage" part. A pro should respond soon.
A fire burned up the old wiring?:eek:
k_buz 07-06-2013 10:31 PM
Wouldn't fly in my area.
If your EC would have pulled a permit, you'd know the answer.
usair 07-06-2013 10:38 PM
why would it not pass inspection in your area?
dgfit 07-06-2013 10:42 PM
It was my thread regarding laundry chute as a possibility for my upcoming home rewire. If my inspector is ok with it then I will need to close it off such that it could ever again be used as a chute, run conduit, and seal it for fire block at top and bottom with fire rated caulk. But the point was made that it would e excellent for hvac so I'm not sure I will go that route.
k_buz 07-06-2013 10:55 PM
The best I can give you is that a laundry chute is not a chase for wiring. It is specifically designed for one use. The best code I could cite is that PVC needs to be protected from physical damage as well.
usair 07-07-2013 07:44 AM
How much damage could shirts and towels do to PVC? Some local amendments defy logic.
Speedy Petey 07-07-2013 07:47 AM
I agree. Unless you are throwing rocks down there I can't see this as any different than pretty much any other area in a residence.
An inspector claiming physical damage is grasping at straws.
k_buz 07-07-2013 08:06 AM
I don't fully agree...
If some one would put PVC in a laundry chute, how would they strap it? Generally, it wouldn't be strapped so the PVC is just kind of floating in there.
As for the method itself, I would say it is similar to running up a cold air return.
dgfit 07-07-2013 08:26 AM
Everything I have understood says you have to completely disable it as a laundry chute which just makes it a metal lines open wall cavity - basically a cold air return. I guess if you could get the liner out then there would be no need for conduit. But it's horrible for fire cuz it gives a straight shot to all floors. I'm going to avoid it for my runs if I can.
