Electrical Junction Box Spacing - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 02:12 PM   #1
KRC
Electrical junction box spacing
Whats the max distance between junction boxes.
Under ground conduit
KRC is offline   Reply With Quote
Old 09-16-2012, 02:20 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No limit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-16-2012, 02:52 PM   #3
Rewards Points: 6,652
There really is no max or min. distance.
Old 09-16-2012, 03:01 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
just to throw this out, if these conduits are for utility use, you better check with them.
Old 09-16-2012, 05:18 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
WHY would you need "junction boxes" for underground conduit?
Old 09-16-2012, 05:44 PM   #6
Pull points most likely.
Old 09-16-2012, 05:51 PM   #7
But WHY???
Old 09-16-2012, 07:00 PM   #8
Master Electrician
Normally underground runs are fairly straight. Unless your going four or five hundered feet I wouldn't worry about it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-17-2012, 01:40 AM   #9
" Euro " electrician
frenchelectrican's Avatar
No limit but only limit is the total of 360 degrees bends 2 - 90's X-whatever 22.5's or 45's or 30's add that up.
Keep the numbers of bend to minuium if possible due it will be easier to pull the conductors.
And be aware of conduit size and numbers of conductors that will affect the whole thing.
Merci,
Marc
Old 09-17-2012, 08:17 AM   #10
But WHY???
Who knows. My guess is as good as yours. Just figured I would throw that out there and see what odd answer I would get from someone, since the majority of these posts are nothing more than spambots.
The Following User Says Thank You to gregzoll For This Useful Post:
Speedy Petey (09-17-2012)
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Electrical junction box - must it be accessable? SKINNY Electrical 13 10-08-2008 07:26 PM
