Originally Posted by RMichels99
I have a marine aquarium and I had a GFCI breaker installed. This breaker kept tripping off. After two months of this I took out the GFCI breaker and put in all GFCI outlets. Two outlets have a powerstrip, not GFCI, plugged in them. Now the outlets are tripping.
When you say they are tripping, you do mean the GFCI part is tripping right? In that case, like Techy said, you have some problem with your equipment and the GFCI is doing its job. You should figure out what is wrong and correct it.
