Electrical Inspection Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 08:45 AM   #1
CAN ANYONE answer my question????? I have built a cabin in Northern Ontario Canada, 20x20, it is in an un-organized township and required no building permits or inspections for the structure (I asked and confermed this). I have read some literature about electrical inspections saying that before you can be hooked up the the service ( or the grid), you have to have an electrical inspection. Makes sense to me, however if I am not going to hook up to the grid, do I need an inspection???
Redsy is offline   Reply With Quote
Old 09-02-2011, 09:05 AM   #2
Rewards Points: 1,016
Welcome to the forum!
If you have no inspection requirements, no occupancy permit requiremnt, and have not service from a power company - then sounds like you have no inspection requirements whatsoever.
If you are installing this yourself and have any question you may want to have a professional electrician double check your work as a safety precausion.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
Redsy (09-02-2011)
Old 09-02-2011, 09:30 AM   #3
Rewards Points: 6,652
Redsy, you may want to drop a email to Mike Holmes Make it Right. They should be able to give you insight on what to do. They have a contact us link at http://mikeholmesinspections.com/contact-us/
Old 09-02-2011, 09:32 AM   #4
Thanks for the link. I'm sure I know what Mike Holmes would say, point taken
Old 09-02-2011, 09:34 AM   #5
Rewards Points: 3,130
Why don't you simply check with your local electric utility? They will know what is required.
Old 09-02-2011, 01:19 PM   #6
In Ontario (regardless of municipality or utility) you would need an inspection from ESA (http://esasafe.com) IF you are connecting to the grid. Your utility would likely be HydroOne if you are connecting to the grid. If you are totally off-grid, no inspection would be required by ESA. However, you should check with your insurance company, they may have particular requirements for your situation.
CuHead is offline   Reply With Quote
Old 09-02-2011, 01:33 PM   #7
They would tell you, that regardless if you are or are not on the grid, the electric, plumbing, and any mechanicals, even structure should still be built in a way, that life or property is not at risk. That means for electric, even if you are running off of genset, Solar, or wind turbine, etc, make sure that the electric is up to code.
People still get shocked and killed from electric in "off the grid" homes.
Old 09-02-2011, 02:55 PM   #8
Thanks to all, I have called around and everyone says I need one. If I just covered it up, I'm sure I would get away with it should nothing go wrong. But for insurace and selling purposes I am going to wire it myself and have it inspected to the panel, then just provide power to the panel by my own means. Have a good one.
Electrical Inspection Question tpagel Electrical 5 06-13-2011 08:12 AM
First time home buyer with question about results of home inspection. autumnredstorm Off Topic 3 09-18-2010 09:47 AM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 01:58 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
Electrical size conduit question pauls Electrical 12 12-03-2008 09:22 PM
