Electrical Inspection - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 11:30 PM   #1
We are renovating and at point where we are wiring for all our kitchen appliances (fridge, gas oven, wall oven & dishwasher) . Is it true that if run lines for all these appliances then we have to purchase ALL the appliances in order to pass Electrical inspection? Because we don't have the money right now buy all the appliances and we can't move back in until we pass electric inspection....If this is true is there any way we can move in without buying ALL the appliances first?
thanks!
-Mike
mike6679 is offline   Reply With Quote
Old 01-08-2010, 11:57 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I know of no area that requires any appliances be in place to pass an electrical inspection. I do no know what your area requires but if you have questions, you should be contacting the inspector or the building department in you area.
Now, to get a certificate of occupancy, which is what is usually required to actually move into a building, you will have had to pass all inspections, electrical, building, health, and any others your area may have.
There may be something in there that requires you to have a heat source in place or functional water supply but as to dishwasher, oven, gas oven, or fridge, I can't see it because I know of no place that even requires any of those in a house let alone not permit you to occupy the house without them.
Old 01-09-2010, 12:10 AM   #3
Rewards Points: 1,016
During my recent major remodel I did not have the appliences in place during the final electrical inspection. Occupancy final inspection required certain things to be installed, such as smoke alarms. Suggest to talk to your building inspector to ensure what is and is not needed to be in place.
Old 01-09-2010, 06:48 AM   #4
Remodeling Contractor
Fixed appliances need to be installed. Smoke detectors need to be installed. Others do not. Like the microwave and refrigerator. These departments are somewhat lax and most likely will understand and allow you to slide. Except for the smoke detectors.
Old 01-09-2010, 10:24 AM   #5
I don't see them requiring all appliances be in place. Smoke/heat and Co detectors, yes. If they required appliances every builder would have to furnish all these while building the house.
Paelectrican is offline   Reply With Quote
Old 01-09-2010, 10:35 AM   #6
nap
You talking to me?
nap's Avatar
I can't say I have had the same experience as you Bob.
a smoke detector system is not what I would define as an appliance but it obviously needs to be in place before occupancy anyway. Unless an appliance is required to be in a home, I see no reason any appliance must be in place to pass an inspection. That would suggest that if you replace any built in appliance, you must obtain a permit and have it inspected. I don't believe that is typical.
there are often times wiring or plumbing is built for future use. As such, it would be ridiculous to fail a building for not having whatever appliance the system was for in place. So, that is why I fall back to the "if it is not required to have such in a house, it will not be required to be in place to obtain a certificate of occupancy" statement. and that has been my experience as well.
obviously any system in place for future use must be terminated in a manner that is safe and acceptable (closed up) if the appliance is not in place.
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Rough electrical inspection - passed today! THANKS!!! vsheetz Electrical 4 02-06-2009 10:42 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 05:52 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 08:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 02:32 PM
