-   -   electrical hookup for a garbage disposal (http://www.diychatroom.com/f18/electrical-hookup-garbage-disposal-90322/)
forresth 12-23-2010 02:37 PM
It didn't come with a plug, and I didn't install the box for on yet.
any reason to not just hook it up direct?
jbfan 12-23-2010 03:11 PM
None.
Make sure you use a clamp where the wires going the dishwasher.
Speedy Petey 12-23-2010 03:29 PM
I NEVER hard wire residential disposals. I always put a 3' appliance cord on and a single receptacle under the sink to facilitate removal/service.
Jackofall1 12-23-2010 03:35 PM
X2 with Speedy
forresth 12-23-2010 03:45 PM
If the only reason is for service or replacement;
I cant say I've ever had to service a disposal apart from spinning it with the allen wrench maybe once every 2 years. I guess my parent's contractor grade unit went out after 25 years, and I went a little higher grade than that. seams like I'd have to replace it 4 times before I'd wish I had put in a plug the first time. I don't think the house will last that long. its looking a bit shaky in areas after the first 90 years.
Speedy Petey 12-23-2010 04:11 PM
It's not just the unit. It makes it MUCH easier to remove in case you have to work under the sink or replace a faucet, etc.
Why do you think most of them have quick release mounting rings?
jbfan 12-23-2010 05:36 PM
DOH! I saw disposal and wired a dishwasher!
I have seen both, but it is much batter wire cord and plug.
Jupe Blue 12-23-2010 06:16 PM
If you choose to direct wire your disposal, you will need to add a breaker lock at the panel for the disposal. This allows a service tech to lock out the disposal when servicing in it. This is actually the code for all direct wired appliances (ovens, dishwasher, etc).
Speedy Petey 12-23-2010 09:11 PM
Although, if the switch is a single-pole, is rated for the load being switched and is indicating (labeled off/on), that is acceptable as a means of disconnect a well.
forresth 12-23-2010 10:34 PM
Thanks for all the advice guys.
I'm not 100% decided yet. My main worry when I was first thinking about it was vibes and solid wire not mixing, but I guess that isn't much of a concern.
looks like I will be routing the bulk of the drain maze behind the disposal, so that is making me learn toward the plug.
1 more quick question; am I correct in thinking that you do not put a disposal on a GFCI protected line?
I believe I read somewhere that there was a code exemption for disposals and washers on the GFCI requirements around water because the plugs are hidden away and electric motor loads tend to falsely trip them.
jbfan 12-23-2010 10:57 PM
Not required to be gfci protect.
jerzeedivr 12-28-2010 01:48 PM
new code
New Code here in Philadelphia, now we install a switched recp. under sink for disposer and a recp. for the dishwasher. you can split the recp. top switched bottom hot all the time for the 2 appliances. Now you will need cord sets to plug in.
forresth 12-28-2010 03:20 PM
thats what I did (splitting the outlet) at my last house. all the extra wires and connections sure fill up a single box pretty quick, especially with 12 gauge. I'm sure we'll see a code against that soon enough.
:whistling2:
in this house, I put the dishwasher in a decent distance from the disposal.
I added the disposal because I had to redo the drain.
I ended up finding a cord that would work (old microwave cord I saved for some reason) and installed the plug.
I guess the main thing was how much it galled me to have a "high-end" disposal not come with a cord, and then have HD try to sell me one for $12 or whatever it is.
:furious:
I certainly would not have bothered removing a cord to direct wire it.
jerzeedivr 12-28-2010 05:29 PM
there is a code for box fill, sounds like your box was too small.
forresth 12-28-2010 07:24 PM
it was a standard box. It probably just seamed fuller bending all of those wires to shove it in. either way, I'd use 2 separate boxes or 14 gage next time.
